  • Replies 130
Good job on the research, saves tears later.
As before; I'm in for 2 sets, PM me some details & I'll cash you up.thumbsup.gif
Cheers. I just hope my research is correct :)
Shouldn't be a prob, if anything like the guy from SPC Performance said, the bolt might just be a few mm long but it's not a problem. Better a little long than short.
I'll PM everyone payment details Wednesday night.
Edited by slippylotion
Ok guys, the chance to get in on this buy is now closed.
I will PM everyone listed below the bank details and final price excluding postage within Australia from me to you.
Please don't pull out of this now as the final price everyone gets is worked out on everyone listed below still paying.
The guys in the buy are:
Slippylotion (myself) x 2 sets
Daleo x 2 sets
Scotty nm35 x 2 sets
Commsman x 2 sets
prince_skyline x 2 sets
skip_o_valov x 2 sets
Thanks everyone for getting in on this so we all save a bit of coin on these.
The shipping from the US is standard international so please allow a few weeks for arrival. As soon as they arrive I will contact you all to arrange postage to you.
Cheers
  • 3 weeks later...
The bolt kits are here guys! Just in time for christmas holidays to fit them on that lazy day.
PM will be sent regarding postage to each of you.
Thanks a heap guys for joining in with me.
Cheers
No problem, so what do we use to slot the hole? Is there any instructions?
The square white piece of card is a template for marking out the wider slot; you just colour with a marker pen and use a die grinder with a rotary burr or dremel to widen the slot.thumbsup.gif
Yeah they come with instructions. Can use either a dremel or die grinder. Maybe a bastard file if you have plenty of strength and time ?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
