I have a t78-33d 17cm on a rb25det and would like to get an idea of the expected power output.
It's currently putting out 280rwkw at 18-19psi on a roller dyno. I thought it would be much more, at least 300-350??
Anyway, specs are as follows.
T78
rb25 highflowed injectors
stainless highmount exhaust manifold
50mm hks copy wastegate. (not plumbed in)
3" exhaust
link g3 ecu
stock inlet manifold
2.5" intercooler piping
china FMIC
stock rb25det block with stock rb25de head
stock nissan headgasket
oil cooler
AFR's on boost are around 11.5 with 10* timing up top.
I will get the dyno sheets and post them up soon.
Thanks in advance.
https://www.sau.com.au/forums/topic/382814-t78-rb25det/
Yea I think so, maybe a 4" exhaust and 22psi.
The engine is just a slapper with parts we had lying around.
From memory the torque drops off pretty hard after peak @ about 5.5k, like there is a great restriction. I thought with the big turbo the torque should be able to hold a bit longer than it does. It won't take much timing though (probably another sign of a restriction) or maybe the DE head has raised the CR to much. -switch it to E85?
Edited by r31 25t
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6106716
This should give you an idea, stock internal 1JZ with 264 cams...this car hasn't backed it up on the strip so i'm not sure how genuine those 640 horses are (dynojet reads a bit higher than a Dyno Dynamics dyno) at 24psi...but should be high 500's out here on a DD roller
Edit to add - 1JZs have smaller ports and half a point less compression than an Rb25det and tend to need a couple more psi in the intake to make the same power using the same turbo.
So I would think that 600hp is there for the taking with a big (4") exhaust a good cooler and a good tuner on E85
  • Like 1
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6106920
I've seen that video before, and there is a write up on the car here supra t78.
The intercooler and exhaust piping sizes are the same as mine according to the posts on the above forum link, but like you say its being run on a dynojet.
Also running the wastegate plumbed out is effectively like having a bigger exhaust so that should help a little?
I may of found the problem, on a closer review of the dyno sheets I've noticed the there is some slippage when the turbo ramps onto boost, whether it's the tyres or the clutch, I'm not sure. - This is probably where the power is being lost, the engine maybe making an extra 20kw of smoke from the clutch or tyres. I'll have to pay more attention next time it's on the rollers.
I'm off to the shed, so will get those sheets posted up today. - no laughing please!! this may be the most inefficient way to make 280kw.
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6107172
Change the piping to 3"
Use a larger intercooler
Get rid of the bov
Use a good one
A twin scroll type turbo manifold
Yes 100mm is a good idea if you can flow power
I'm running a rb25 t78-33d with 270-272 camshaft set up
I'm at 400hp at 10psi 100mm straight pipe with a vibrant 100mm muffler port and polish etc.
Been running for 3yrs + no problems
If you have any question just pm me
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6107591
Power and torque are in kw and nm and I can't remember how I scaled the knock.
KW NM AFR
KW NM MAP
KW NM Knock
I'm still working the bugs out on the dyno too which doesn't help much.
I put a tilton triple in it the car today and it feels way more savage to drive.
Didn't get enough time to put it on the dyno though so not sure if it's transferring more power.
Any way don't laugh to hard.
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6107782
Why only 22psi? Just keep screwing more in until it stops making power or you run into detonation issues.
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6108066
I know what your saying but if the torque is falling away that much with such a large turbo then surely something is restricting things. Would be worth pumping up the boost to see if it overcomes the issue or it gets worse as a test.
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6108746
Yeah fix the problems first, I just thought that was your goal once it was all running properly.
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6109062
Firstly I applaud your efforts and your attitude mate, good on you for trying to nut this out.
My question is: Is the manifold twin or single scroll and is the turbine housing twin or single scroll?
I have found poorly matched flanges to the head/turbo/dumps/cats ETC ETC to cause enormous restrictions like what you are seeing. It is a lot of flow and a little bit of turbulence would be exponentially worse for its power making ability as the flow climbs.
Check this out and make sure everything is nicely matching up. See if your manifold has carbon deposits on the flanges indicating a poor flow path ETC.
Also, and perhaps more importantly, I have come across another RB slapper recently that had the exhaust cam out by 1 tooth... It just did not want to make the same power it did before because it was ingesting exhaust gas once the boost came on and killing off its spark ability. Make sure the cams you are running are in spect with the belt/camgears you are using and its all timed up 100%
  • Like 1
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6109111
The main reason is the G3's internal map sensor is only limited to around that boost and I'm to tight/lazy to buy another one and wire it in, and to be honest it should be more, the numbers are indicating a problem.
johnnilicte[/color]' date='14 November 2011 - 11:35am' post='1735291']
What duration cams are you running?
Factory r33 rb25de cylinder head and camshafts I=240* E=240* 7.8mm lift Same cams as the rb25det according to the tomei website.
I think the head has bumped the CR up a bit - needs to be tested.
GTScotT[/color]' date='14 November 2011 - 04:19pm' post='1735291']
Thanks mate.
The manifold is definitely a twinscroll, not to sure how well it lines up with the turbo flange, will have to check that to.
Timing is spot on.
I think all going to plan, I'll have it back on the rollers next saturday with a dump pipe only. - It's gunna be loud, but hopefully it makes the numbers.
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6109613
Twin scroll with be best.
I run a single scroll equal length love fab turbo header with a tial 60mm wg.
Spool test was at .7 bar no boost controller.
Results was:
5 psi at 3,200 rpm
10 psi at 4,300 rpm
Which was fool boost
We set our rev limit to 5,000 rpm
Which was hitting rev limit at 4,800rpm
You can check out Kelford camshafts
They use a lower lift but the same duration as my tomei.
Mine is 10.25 both camshafts
They do help spool
https://www.sau.com.au/forums/topic/382814-t78-rb25det/#findComment-6110424
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
