You can't go wrong with NISMO or Tomei injectors for top quality after market injectors
555cc injectors will do the job nicely but if you are considering any more power than 300rwkw or going down the E85 path in the future then you may want to consider 740cc
They are usually cheapest direct from Japan (RHD, Nengun) I got mine through Jessie Streeter and saved a few hundred $$$...
Google his website and drop him an email, he is really good to deal with and plenty of SAU users have used his services
FYI you need side-feed injectors for the RB25DET
Good luck!
Hi,
Looking for new injectors for my RB25 R33 gts-t. I am looking for around 300rwkw. What size should I go and where is the best place to buy them online ?
thanks
https://www.sau.com.au/forums/topic/383376-injectors/#findComment-6115699
What about the ID725's?
Should be able to get them out of the US with a rail cheaper than the NISMO's
Did notice yesterday that there are SARD 650s and 850's going for $650 on yahoo japan (this is for 1j's but im sure RB25s would be the same)
https://www.sau.com.au/forums/topic/383376-injectors/#findComment-6117729
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
