S A U N S W - Texi, Sos, 12Th February 2012
  • Replies 209
Posted Images
i seem to pull around 1-1.2G on the street with no worries.
and the last "kahna" type event i went in, was also ok.
ive got plugs to install for the speaker wiring, just not the power.... ....yet.
and still have to buy an extinguisher.
but looking forward to the day.
my first texi, im a little excited :woot:
Tats had metal brackets holding his in... A couple of spins dis lodged it... It then smashed the outter guards to pieces... Causing the car to be around 1 - 2 inches wider on each side...
You will be surprised the G-Forces that you pull when you spin a car...
ill im getting from this is cheap pumped guards....
joking, joking, will work on the wiring leading up to the event.
and besides, my straps rated to 2T im pretty sure, and mounted off the rear strut brace, it looks so hectic, all the wimenz drop their pants at the very sight of it :P
Hi all
I'm in as a first timer for TEXI but have let my membershgip lapse,. I will rejoin on the day.
Also, I have sold my V35 and will attend in my...er...um...er... XR8, hope that is okay?
Regards
Geoff
Entry fee paid. Ref : Texi Ryan Ambrose
re the ASAA license- I paid and supplied forms last time, should I have received something in the mail? I have no license number to put down.
now to find money for a new clutch pinch.gif ( or not do hard launches )
car won't be ready fellas, but i will be there spectating and taking some happy snaps.
whens the next one due after this?
All the club events are listed in the 2012 events thread, link is above in the last post of mine
Yes shouldve, we can sort that on the day worst case
This event is now on the clubs facebook page, click the link and share with your friends please! Without people coming to these events the club wont put them on :)
http://www.facebook.com/events/148447388602927/
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
