hahah yeah
actually in my case...it is the fact that I dont want to go buy new brake pads, have the semis fitted to the wheels that are currently on the Soarer, change brake fluid, wheel alignment, change oil etc etc
Nor do I want to push a 20 year old car that I will have owned for only a couple of weeks
