ok, so hi all. pretty bored atmo so thought id start up a build thread, basically ive owned the car for 8 years and am now finally getting it to a point were im getting happy with it, i have a heap more planned for it still so thought nows a good a time then any.
cars gone throu a few changes, mainly f/end and engines. 2 fj20s, 1rb20, 3 rb25s 1 rb30/25 and now 26/30.
[this is one of the early pics i got of it, if i find more ill put up
went drifting
first drift day at op, basically stok every thing sukd pretty bad
2nd and 3rd time, getting better......
last time at op...
https://www.sau.com.au/forums/topic/384136-dr30-build/
ok so ive got a heap more inbeetween photos ill put up later but 4 now ill try to bring this all up to speed, after the last time i drifted it about 9 or so months ago, id gottn sik of emptying the catch can every pass, i tried all the tricks to combat this, but inevitably the motor was pumped.
motor pulled out with the plan to just re ring it and put bak in, didnt quite happen that way...
got an offor 4 the microtech, so sold that and it went from there.
parted out old motor and setup.
while waiting 4 bits (and $) got a bit bored and shit got outa hand!
with fitment came other issues, i could only bash so much and couldnt bring myself to totally tub it so after a lot of thinking and a couple a cans of courage i took to the inner front gaurds
cut out gaurd
move forward40mm
wat have i done! no turning bak now
ad filler section and prime 4 paint, engine bay stich welded. props to gav 4 the welding and help, guys a pro
Edited by ydr030
https://www.sau.com.au/forums/topic/384136-dr30-build/#findComment-6128896
cheers guys! yea every one was sayin paint it silver or blak!! wasnt interested, ive always been a fan of 2tone cars and id like to try atleast keep the exterior original lol
yea not sure on the wheels,ive had them on the car 4 years, just only recently got some dishs made for them. all i no is they are old school speedstars, i carnt find ne info on em ne one have ne ideas?
ok so, when motor was out i thought id fix all the movement in the steering, turns out the drag link balljoints, arent serviceable, so basically, i had to find a new complete arm, or go rose jointed. carnt get the part ne more. no were had them. didint want rose joints 4 wat i was doing with the car. priced up the steering box rebuild and nearly had a heart attack, so after a few more cans i thought f it, try to convert it to rack in pinion. so far so good its still worked out cheaper than it was to rebuild the steering box!
trialed fitted with a 33 x member and rack, but motor sat to farward, ended up using a r32 crossmember with the 33 rack, and s13 lcas, 4 now.
pintara steering coloum only needed minor mods to fit,
just had to shorten 15mm
while it was all apart i added asolid steering bush, these things a re awsome, made a massive change to the movement in the colum
still havent driven the car yet, so dont no how it drives, fingers crossed its ok
https://www.sau.com.au/forums/topic/384136-dr30-build/#findComment-6130666
Very nice, love the DR30 and with an RB up front you've got the best of both worlds.How hard/much is it roughly to get a DR30 RB converted?
There's a rolling shell for sale near me that comes with a 25/30, 25 loom and box, and this thread/car are making it real hard for me to not sell my 32 and get it.
I just keep thinking taking on something like this would be a bit over my head.
https://www.sau.com.au/forums/topic/384136-dr30-build/#findComment-6130999
with motor in, found the wastegate pipe is too long and dont have enough room to run a dump pipe,
mani removed, wastegate shortened, screemer made
didnt like the stainless piping ne more so changed to alloy
to add a bit more awsome, top cooloant outlet was modded
dump pipe on the way
https://www.sau.com.au/forums/topic/384136-dr30-build/#findComment-6140745
yewwwww!!! car back from petes and RUNNING!!!!! been along time coming but finally the cars running again!! massive thanks to pete and juzzo 4 letting me break in his car trailer haha,
car still needs abit more work till i can drive it on the street and ready for a tune, hopefully early next year...
pete is a freak, awsome wiring job! could not be happier
https://www.sau.com.au/forums/topic/384136-dr30-build/#findComment-6154075
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
