Hi mate, I replied to your question in the 4 sale thread (in the stagea forum).
But for eveyone else, I'm waiting on some throttle harnesses to arrive. They were out of stock when I first ordered the units. Once they're in, the last 6 can be sent out.
I have names listed against all but 2. So if you want one, let me know soon because once they're gone that's it.
Cheers, Leon.
Hi Leon,
If the kit works the same on a V35 series 2 (2005) - I'll take 1.
It's a manual, would you recomend any special install (eg. clutch switch)?
Cheers
Mark
I have a manual & got the same kit from Leon (which is awesome BTW), I ended up getting a clutch kit from AutoBarn for about $30. The whole system works really well.
Here is a DIY Guide i have done
http://g35driver.com/forums/audio-video-electronics/395674-diy-g35-350gt-v35-cruise-control.html
P.S for manual you will need clutch switch if you really want it... Stock on is way to hard to get to.
Oh and click click the on button, do not hold it on or it will turn on with a speed limit function not cruise control...
Manc01 do u mind posting pics of your clutch setup please?
Cheers, Leon.
Hi leon,
Are these a genuine Nissan (radar type)kit which I beleive came from factory and if so, do you have the genuine part number. I would like to cross reference it in 'Fast' and see if it will suit my auto PM35. If it does fit can you put my name down for one.
:thanks:
Hi leon,
:thanks:
G'day Frank
no, they are not the Nissan radar cruise - thankfully. From what I've read of those, they have common problems like deactivating from oncoming traffic, have issues with the radar lenses getting dirty or misaligned etc & also can't be set above a relatively low speed (105 - 110km/h I think).
The ones I have are sometimes used in OEM applications, but normally supplied aftermarket. The only part number you will need to comfirm is if the steering wheel, & therefore the control panels, are the same between the NM35 & PM35 (I suspect they are) as that is the only genuine Nissan part supplied with the kit. The part number for both panels of switches is 25550-AC700. These are from the later G35's (2005/6/7 I think) & have inbuilt LEDs to provide backlighting for the buttons.
The rest of the kit consists of the throttle harness (intercepts the DBW throttle voltages) & the main unit which is the brains, plus some wires to connect the bits & bobs req'd for it to work.
I'll put your name down for now & PM you later to confirm. Let me know at any time if you are certain you do not want it, as I know there will be someone to take your place.
Regards, Leon.
  • 1 month later...
  • 8 months later...
  • 2 years later...
Hi guys, major thread resurrection going on :)
Due to demand, I bought another dozen cruise controls recently & added the car specific bits together to make up a kit.
But I have a couple of kits still for sale thanks to some M35 guys not responding to messages.
They come preprogrammed for PnP, DIY install. Once installed you can adjust throttle response parameters however you like (the settings were uploaded from my M35).
They come with factory switches with led back lighting. The audio controls will work your factory head unit or can control aftermarket head units depending on make/model. I can sell a kit without switches if you want to do something different, like use a stalk for a non standard steering wheel.
If you have a manual transmission you will need a clutch switch as well (a brake switch from autoparts store is cheap & easy to find - my CC supplier quoted $15).
Cost for the complete kit is $615 delivered (includes all harnesses for throttle & to connect the factory switches with lighting - it's actually a lot better than the first time I did this).
PM me if interested. It's been years since the last lot & I'm not making this a common occurrence so get in early if you want one.
Cheers, Leon.
Well done Leon; good to hear you've got these available.
To any potential buyers; you would be an IDIOT not to buy one of these kits, it is possibly the best mod you'll ever do to your car.
Seamless integration, and super reliable.
Grab one while you can.
Was one of the best things that I did for my M35 Stagea... As I had a non OEM steeting wheel (Momo) the OEM switches did not fit, so I used the stalk included with the kit.
If only the kit I fitted to my V36 had been as good as Leon's... The steering wheel mounted controls were a huge pain to fit, do not look as good and do not have the preset speeds which I got on the stalk in Leon's kit..
Adding cruise to your V35 or M35 is something you will not regret... :yes:
+1 to the above.. I installed one of the kits Leon supplied a few years back and it has been excellent. The ability to make adjustments to gain and sensitivity make it much better than factory cruise control units I have used in the past! The clutch switch for the manual was an easy add-on.
  • Like 1
  • 5 months later...
  • 9 months later...
  • 1 month later...
I know this is an old post, but do you still have these kits?
Just saw this today, http://www.sinergymotorsports.com.au/cart/products-page/nissan-skyline-v35/cruise-control-nissan-skyline-v35/
Not sure the source of these kits, they're definitely new to that site though.
I'm in SA and am looking to get one of these kits from Sinergy Motorsport in the near future. If anyone else gets/has got one already, let me know what you think of it. If anyone knows of a cheaper place to get these, that would also be appreciated!
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
