  • Replies 5.5k
Posted Images
That's because they didn't show him on airtime at all for whatever reason, had a reasonable race by the looks of it!
Reasonable race overall, lots of stuff ups still with penalties and pit issues.
Also interesting to see the RBR team with a clear issue with the front nose cone.
No-one seriously hurt I trust.
Glad the fire didn't start during the race.
Someone at the celebratory dinner has got to say, "Pass da pasta Pastor"
From best previous performance of 8th > 1st now is great news & great driving.
Williams working to determine cause of fire, FIA says 31 people treated in total
It is so far confirmed only nine members were from F1 teams but other team personnel were understood to be involved.
Caterham said four of its members had been taken to the medical centre for examination, while another Force India mechanic had also suffered from smoke inhalation and was under observation.
Formula 1's ruling body, the FIA, said a total of 31 people were seen by medical staff from the circuit. Seven had been transferred to local hospitals.
http://www.autosport...rt.php/id/99605
no one seriously hurt that we know of terry.
nice to see people form other teams helping them.
PS Pic 4:- Those red hoses need reinforcement in the walls, since they kink badly
Aren't those lay flat hoses? THey store flat on a reel (take up less space) and only fill out when they've got high pressure in them. If so, those kinks will do nothing to stem the flow. The hose is flexible enough to allow the water through, even with the kinks in them. The amount of water they flow is overkill anyway (if you have good pressure) so the small reduction in flow won't make a big difference to their firefighting needs.
Thanks, I'll accept that; but the same hose in Pic 3 seems to be emitting better flow (notwithstanding that the pressure + the nozzle position are the same).
Overkill? In this instance, you're probably right. Ta.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
