  • Replies 5.5k
Posted Images
Generally...the Lotus just looks awesome. Romain out qualified Kmi again. Hope the podium is Webz, Romain and Kimi
Q: We've had some particularly variable weather over the last three days and we were expecting a wet qualifying session; are you expecting or afraid of a wet race or do you think it's going to stay dry?
MS: I'm expecting, at my pit stop, that it will start raining.
NR: Local knowledge hasn't really helped the last few days. It's been very unusual, that's not the normal weather here, that in the morning we have sunshine and then in the afternoon everything goes dark. It's very strange.
MW: I just do whatever Jenson does! ;)
Re Pastor...They are saying there was nothing in the data to suggest it was deliberate and the penalty was for simply hitting Perez in what they have said was an avoidable accident
Maldonado starts dead last on grid. I like that.
I maintain that he's a n00b. Look how he crashed in Oz, never seen anyone hit that wall before.
Crashing into Perez (who was way off the racing line) is just brain dead. I would ask "what was he thinking" by being there but the answer is obviously not much.
The only good thing about Maldonardo is getting to perve on his fiance.
+2nd that.
Accoding to this site he is lucky to be racing at all this weekend
not to mention he did the same thing to Lewis last year at Spa, deliberately ramming him when he was held up
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
