  • Replies 5.5k
Posted Images
Lewis Hamilton continued to set the pace in Canada as the McLaren driver finished a mere 0.054s ahead of Fernando Alonso on Friday afternoon.
Jean-Eric Vergne got proceedings underway with a 1:21.108 but within five minutes was outside the top ten with Kamui Kobayashi, Kimi Raikkonen and Nico Rosberg taking the P1 slot. The benchmark was down to 1:16.738.
Pastor Maldonado was the next to lead the way as Timo Glock had the sessions first incident as he spun his Marussia at Turn 1 and came to a halt in the middle of the track facing the wrong direction. Thankfully everyone was aware he was there and avoided him before he spun around and continued on his way.
Rosberg returned to the front before losing out to Fernando Alonso. Minutes later the Spaniard became the latest in a long list to get it wrong at Turn 8. But while most cut the grass, Alonso put his F2012 into a full 360' across the grass and returned to the action at Turn 9.
Lewis Hamilton took over at the front on the super soft tyres and lap by lap lowered his lap time to a 1:15.439. With drivers switching to longer runs, Hamilton was secure in the P1 slot when the session was red flagged.
With 40 minutes remaining in practice, Bruno Senna lost the back end of his Williams into the Turn 14, the infamous Wall of Champions. The Brazilian, who was testing the latest rear wing, hit it backwards hard before his FW34 rebounded to hit the wall again with the front right.
Back underway with 30 minutes left, the drivers were quickly out on track. The two Ferraris were the big movers with Alonso taking second place, 0.054s down on Hamilton, and Felipe Massa third.
Practice Two ended with Hamilton in the P1 slot with a 1:15.259 followed by the two Ferraris. Sebastian Vettel was fourth while a late appearance from Jenson Button after a gearbox change put him down in 13th place.
Times
01 Lewis Hamilton McLaren 1:15.259 43 laps
02 Fernando Alonso Ferrari 1:15.313 0.054 36 laps
03 Felipe Massa Ferrari 1:15.410 0.151 39 laps
04 Sebastian Vettel Red Bull 1:15.531 0.272 44 laps
05 Paul di Resta Force India 1:15.544 0.285 32 laps
06 Kamui Kobayashi Sauber 1:15.651 0.392 37 laps
07 Michael Schumacher Mercedes 1:15.697 0.438 32 laps
08 Nico Hulkenberg Force India 1:15.799 0.540 39 laps
09 Jenson Button McLaren 1:15.812 0.553 14 laps
10 Nico Rosberg Mercedes 1:15.878 0.619 40 laps
11 Sergio Perez Sauber 1:15.898 0.639 38 laps
12 Mark Webber Red Bull 1:15.907 0.648 41 laps
13 Pastor Maldonado Williams 1:15.987 0.728 39 laps
14 Romain Grosjean Lotus 1:16.360 1.101 29 laps
15 Kimi Raikkonen Lotus 1:16.562 1.303 33 laps
16 Heikki Kovalainen Caterham 1:16.981 1.722 24 laps
17 Bruno Senna Williams 1:17.022 1.763 22 laps
18 Vitaly Petrov Caterham 1:17.075 1.816 41 laps
19 Jean-Eric Vergne Toro Rosso 1:17.124 1.865 41 laps
20 Daniel Ricciardo Toro Rosso 1:17.716 2.457 34 laps
21 Pedro de la Rosa HRT 1:18.908 3.649 27 laps
22 Timo Glock Marussia 1:19.084 3.825 40 laps
23 Narain Karthikeyan HRT 1:19.378 4.119 21 laps
24 Charles Pic Marussia 1:19.902 4.643 18 laps
http://www.planetf1.com/news/3213/7801713/Hamilton-Remains-The-Driver-To-Beat
Senna is going to find himself coming under rather close scrutiny soon. I am pretty confident in saying Rubens would have smashed his performances to date in the same car....and Williams will be having to look very hard for any signs of promise in light of the fact they have a competitive car and yet Senna has had some rather poor showings.
I like the guy and want to see him do well...but :( A bit like Dan, I think he needs some strong showings in the next few races and that French Fellow (FF) is doing a great job in the races
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
