  • Replies 5.5k
Posted Images
2 races in a row where Pirellis haven't fallen apart...
2 races in a row where the lottery effect of random people turning up high on the grid and in race results hasn't happened...
I'm tipping they've quietly changed back to last year's compounds. Either that or every team in the field suddenly worked out how to make the tyres last at exactly the same time...
Edited by hrd-hr30
Well it looks like Nando should almost certainly get another drivers title this year. To not, He'd need to start having a heap of shit results, or the Ferrari to lag heavily behind it's main rival's development in the last half of the season. Can't really see either of those things being the case.
I'd love to be proven wrong, but have a feeling I won't be...
Nige and his fkn huge balls at 1:04
webber throwing in his usual no-show
this is exactly why he will not be a WDC
Unfortunate isn't it?
Note to Webber: The best in any profession don't take days off.
Edited by iamhe77
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
