It's not the rules that f**ked Vettel, Red Bull just didn't put enough fuel in.
It's not a hard rule to follow, not as though they ask you to do something near impossible, like the driver must exit the car at 50km/h, jump through the official qualifying ring and land on both feet.
Red Bull didn't want to take an extra couple of kgs around with them, and it may, just may cost them the championship.
Hilarious.
  • Replies 5.5k
Posted Images
Also, wtf is with Senna, how can two driver's pace be so different.
Since Williams love money, I want to see Red Bull buy Senna's seat for the last few GP's and put D Ric in there, like they did with HRT. Pastor proves the car can have pace and I reckon Dan would do well in a faster car, if only as an experiment for as couple of races. He put the Torro Rosso up the pointy end of the grid in Bahrain, never know what could happen.
I think the safer bet is predicting Pasta will take out Webber on the first corner, or Webber to finish 4th at best with a slow start relegating him to 8th by turn 3.
Also, Vettel will be his usual peeved self and I think he will get into the top 5 if he doesn't have a tangle with Massa...who should do the team thing and take him out :)
Difference between starting from the back and coming from the back due to track position and pitstops is that there are no blue flags when you're passing for position.
and in a Race car, no one can hear you scream ;)
This guy. My thoughts exactly.
Hilarious.
yeah, but what does 150mL of petrol weigh? barely more than 100g
:rofl:
I think the rule makes sense. It does seem harsh but how dangerous is it for cars to be on their mega hot lap and those that ran before with 30seconds to go on the clock are stopping by the side of the track as they didnt want to carry the fuel around with them. Considering the top 10 are covered by 1.1 seconds with 2nd to 6th less then 0.3 seconds apart there is a spot of two to be gained from being a few kgs lighter on fuel. The other thing is that the cars weight is inc fuel, so they need enough for a sample and also enough that they are not underweight
there's no way homo can hold that type of pace through out the race, he was really violent with the throttle the whole way around the track and he was also on the limiter for what sounded like 3/4 of the back straight, if mark can get close homo will have no defence against him. ;)
I turned it off the second they finished q3 as it was pretty much championship over with Alonso so far back... but reading that vettel wasdwas dropped back has re-sparked my interest. I think he'll easily get into the top 10 and score some points, so Alonso really needs to maximise the poten-cial and get back in it!
Fingers crossed vettel gets taken out on the first lap trying to hard to gain places early
who says RB have any race pace?
if Vettel's trouble was anything to go by, they were running the cars on fumes during quali to try and make the top 3
both the RB would have been in the top 5 (originally second and third) where's the other mac?
button would of been seventh..
homo got mad and pulled one out of his arse.
Vettel couldn't have picked a better time to start at the rear really...With Alonso in 6th, 2 Macs, an RBR a Lotus and a fast Williams in front of him, I can't see him making up too many places.
I like to be negative so I'm happier if it goes better than I expect lol
Vettel was still 4 tenths off the pace and obviously without enough fuel to make it home...
Abu Dhabi GP: Red Bull says Vettel's car had enough fuel
Red Bull team principal Christian Horner is convinced that the necessary fuel for the mandatory one-litre sample was in Sebastian Vettel's car but that regulations preventing the removal of bodywork meant that it could not be extracted.
The FIA stewards' decision stated that scrutineers found "an insufficient quantity of fuel for sampling purposes", which led to Vettel being excluded from qualifying.
But Horner, who accepted that the penalty was fair, insists that the fuel was there, but that a full litre could not be extracted without removing bodywork, in contravention of Article 6.6.4 of the Formula 1 technical regulations.
"The rules dictate that one litre has to be able to be provided without the removal of bodywork, without manipulating the car," said Horner.
"We believe that the fuel is in the cell, according to what Renault have told us, but you cannot dismantle the cell to give the sample.
"The car will be worked on tonight, so it is out of parc ferme, and we should have a better understanding and hopefully a cure for tomorrow."
The need for fuel sampling is covered by Article 6.6 of the F1 technical regulations, which reads:
6.6 Fuel draining and sampling
6.6.1 Competitors must provide a means of removing all fuel from the car.
6.6.2 Competitors must ensure that a one litre sample of fuel may be taken from the car at any time during the Event.
Except in cases of force majeure (accepted as such by the stewards of the meeting), if a sample of fuel is required after a practice session the car concerned must have first been driven back to the pits under its own power.
6.6.3 All cars must be fitted with a -2 'Symetrics' male fitting in order to facilitate fuel sampling. If an electric pump on board the car cannot be used to remove the fuel an externally connected one may be used provided it is evident that a representative fuel sample is being taken. If an external pump is used it must be possible to connect the FIA sampling hose to it and any hose between the car and pump must be -3 in diameter and not exceed 2m in length. Details of the fuel sampling hose may be found in the Appendix to these regulations.
6.6.4 The sampling procedure must not necessitate starting the engine or the removal of bodywork (other than the cover over any refuelling connector).
http://www.autosport...t.php/id/104004
Abu Dhabi GP: Red Bull baffled by Vettel fuel problems
Red Bull says it is baffled as to the nature of the fuel cell problem on Sebastian Vettel's car that resulted in him getting thrown out of qualifying for the Abu Dhabi Grand Prix.
Vettel will start from the pitlane at the Yas Marina circuit on Sunday after he was disqualified from his third place slot on the grid for not having enough fuel in his car for a mandatory one-litre fuel sample to be taken.
With the team and Renault both convinced there was enough fuel in the car to provide the sample - but the limits of the regulations preventing it being extracted – the FIA had no choice but to exclude Vettel from the results.
Red Bull team principal Christian Horner said on Saturday night that his outfit and Renault had no immediate answers for what had gone wrong, which is why Vettel's car was being pulled from parc ferme so a full investigation could be undertaken.
"It is frustrating. It's annoying. It is one of those things," explained Horner, whose team had successfully proven that there was a 'force majeure' reason for stopping Vettel after his qualifying effort.
"It is an issue that was reported on the in-lap. The instruction from Renault was clear. They wanted us to stop the engine immediately due to an issue that they saw within the fuel cell. We did that.
"The FIA accepted that, they accepted the technical issue that Renault reported to us, and unfortunately as the regulations dictate there has to be a one litre fuel sample to be able to taken from the car, and it is only 850ml that has been extracted.
"Renault are convinced that the rest of the fuel is in the tank but we have taken the car out of parc ferme tonight to further investigate."
He added: "It is a frustrating scenario and we need to get into the fuel cell to understand what the issue is. We are working with Renault on it, and they dictate the amount of fuel that goes into the car.
"They are happy with the margins, they are happy with the amount of fuel that should be in the car but for whatever reason we have had this issue on the slow down lap."
Vettel's car being taken out of parc ferme means he will now start from the pitlane, which is a blow to his hopes of further extending his points advantage over Fernando Alonso in the championship table.
Horner said, however, that there were still opportunities for Vettel to limit the damage of what has happened.
When asked what impact he believed the result would have on the title battle he said: "It is difficult to say.
"There is a long race ahead of us and there is an opportunity, so we will go into the race, we will attack the race and I am sure Sebastian will demonstrate to everybody why he is a great racer.
"He has come from the back and produced great races before and I have no doubt he can do it again. There is no reason why Sebastian cannot salvage something.
http://www.autosport.com/news/report.php/id/104005
enjoy that read.. :P
well Lewis won here last year and he hasn't looked anything less than formidable so far this meet, so I'm calling it 2 from 2 right meow
you're welcome
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
