  • Replies 5.5k
Posted Images
Grosjean needs to take out Vettel, and 5 other people who qualify ahead of Alonso in Brazil to level the ledger and make it a fair championship battle!
Edited by hrd-hr30
pfft.
the championship is fair. RBR have just been better. Ferrari have had a dog of a car all year and Alonso has had more than his fair share of "help" from his teammate. Sorry Massa we're just going to break the seal on the gearbox, not actually do any work on it but just enough to give you a 5 pace grid drop and help Alonso.
To his credit, Alonso can (and has) driven a turd across the line for a place. He is an amazing talent. I don't think anyone gets away with more than Ferrari as far as the FIA are concerned though.
What happened to Schuey?
Pretty much circulated going backwards all race with nary a whimper barring his chop on Button. The slippery track should have suited him. Is Mercedes the new Toyota?
At least they'll replace him next year with somebody who can make up for the lack of race pace with some quali speed
Edited by ctjet
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
