I have noticed this since last week, for some reason I can write in this thread. When I click to "reply" or "quote" it takes me to a page where i can view other peoples posts, and I can click on emoticons and add photos, but their is no provision for actually typing anything in, no reply box comes up. When I try to click "post" it doesn't respond either.
Hope this message gets through.
Ok in this thread I can write in the "fast reply" box, but I can not quote or click the "add reply" button as it opens a window that does not let me type in a reply.
Hope this info helps.
Also can not alter profile info or use any of the functions in my profile, which I never use but I tried it out and it says "action failed".
Initially I quoted a massive piece of code, but tags inside that piece interfered with forum engine big time, so I had to remove the post altoghether. So the idea is that somebody should check their closing tags better, not all browsers automatically close open tags, and not many of those that do do so properly.
In the module
<div id="google_ads_div_SAU_ATF_728_ad_container">
The first ad insert is commented, like this
<script type="text/javascript"><!-- google_ad_client = "ca-pub-8812745528911697"; /* Internal Page Top */ google_ad_slot = "9358753284"; google_ad_width = 728; google_ad_height = 90; //--></script>
but is written properly.
The second ad inserting script
<script src="http://pagead2.googlesyndication.com/pagead/show_ads.js" type="text/javascript"> _WTF? Something's missing here!_ </div>
has no closing </SCRIPT> tag
Should be adjusted to look like
<script src="http://pagead2.googlesyndication.com/pagead/show_ads.js" type="text/javascript"></script> </div>
That basically basically fixes everything. For me anyway.
Regards
Edited by Legionnaire
  • 3 weeks later...
Just to add chaps, nothing that already hasn't been mentioned.
The problem I have is that I can't Sign In to make a post or thread at all.
I've tried Firefox, Explorer, Chrome and Opera.
When I click on the Sign In tab all that comes up is the add box and nothing else.
The only thing is can post on is my mobile phone (iPhone)
Edited by OLLIE_NZ
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
