how did I know that video was what was in the link.
old tech twins vs new tech billet single
should have used a GT3582 from an XR6 turbo. that would have been a better comparison since the compressor wheels are all of similar design and the only variable would have been twin vs single.
What if he had used newer gtx2863 vs older gt3582 single?
I posted this in the comments of the video but I'm still awaiting a reply
It doesn't matter if it's new or old tech, my old T4 divided T04Z set up shat all over low mounts and people think they were designed the same age as a dinosaur!
put your graph up then. tell me what twins you shat on. Edited by mr skidz
I don't care if twins or singles or semantics of the debate as there are loads of variables.... But one very good point is I would love to see the singles performance with the gate plumbed back so it's at least attempting to be a street able road car.
My experience, albeit at ~300rwkws and 80mm exhaust is it makes a huge difference to power, response and ignition the tune can take when switching external gate to plumb back...as an observation the quality of the front pipes seem to have a decent impact on twins too.
That said...if there was a reasonable process to getting a single thru roadworthy i would stick with a single every time....just for convenience and simplicity when banging around on track
  • Like 1
The graph and others have been posted on this forum for the last 10 or so years. Dash 5s are the easiest to compare the 7s and 9s are slightly more responsive but made 200HP less
Fairly sure Matt over here runs a RB30 with EFR8374 internal gate and it has no issues with power or response. Mind you E85 changes the game a little Edited by SimonR32
put your T04Z graph up the one that apparently shits on low mounts.
only interested in your claims atm.
so tell me bout this setup of yours..
Edited by mr skidz
looks laggy as shit, looks like a hill climb event. nothing until 120 130kph
so let's be honest they shat on nothing that's not your car or turbo & it was probably stroked.
let's leave this thread for its intended purpose which was GTX related
Edited by mr skidz
210hp and 15psi at 4000rpm on BP98 is laggy? Please... no RB26 makes good power before 4000rpm and people like to post graphs that start at 4000rpm to make them look fatter
That's also 4th gear, if I short changed from 3rd to 4th at 6200rpm it would still be making 420rwhp which is more than the max power -7/-9 would make on the same fuel.
Not my car? Really? Stroked? Really? Here is my sale thread for when I sold it, also you might notice the "Genuine R33 GTR Crank"
http://www.sau.com.au/forums/topic/206647-r32-gtr-430rwkw575rwhp-immaculate/
Edited by SimonR32
FFS this is a thread about GTX twins. Not some dinosaur T04Z.
Wow, steep curve. Not a single f**king torque curve to be seen. Probably don't even know what "area under the curve" means. It means a usable powerband. Not some dyno queen looking graph.
GTFO, I'm sick of reading this shit. I want to know about GTX twins. I like my engine bay to look stock. And it still does.
To the others - When $$$ permits, I'm considering GTX2860s in stock compressor covers and 0.63 rears. I want something more responsive than my -5s. I'm getting 23psi at 4800rpm in 3rd and I want it to be at least 600rpm earlier. I would prefer 20psi by 4,000rpm. Would bring the torque up earlier and hold it with the GTX compressors better efficiency at higher boost levels.
(I use the car for the type of track that has corners..)
Edited by The Mafia
The second graph has a nice fat torque curve for you to see. The car makes the same power down low (if not more than low mounts), it just looks "dyno queen" because it makes so much more top end.
You want some GTX twin results, here is a GTX2863 result on a 2.8L
10518305_815854931771310_549531332373346
and here is it getting matched down low and then losing up top to a stock bottom end 2.6L
As for the track that has corners? You mean where single turbo set ups dominate? I'd love to see some videos of you at the track :)
Edited by SimonR32
  • Like 1
I'm shit at the track.
But looking at that - it goes from nothing to 700nm within 1000rpm, and then it falls away 2,500rpm later. It has a 2,500rpm usable powerband? How is that useful? And having power go from nothing to everything within 1000rpm is definitely useless.
How about a powerband that is 4,000rpm to 5,000rpm wide? More logical one would think....
You also seem like one of those people that thinks that if you have a high power number, you're an awesome driver? Nope.
That dyno is the shittest I have ever seen for track use.
Single vs twin... who gives a f**k, as long as there is a usable powerband.
Edited by The Mafia
  • Like 1
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
