Hey ryan.
I don't think I've taken photos of the undercar surges.
I have one that is R33 specific, r32 ones don't fit.
Door trims are not a problem either but I only make those to suit the vehicle installation included in the price. The doors require some modifications to fit them neatly on the R33 which I rather do myself.
Hey ryan.
Sounds the money I have some doors here I could drop down if that would work.
When you have five call me or pm me a price for each part, next year will be fine bud if you are enjoying your break.
Cheers
Yeah I run one under the car that looks stragely similar. It's the only sensible way to do it....why would you want fuel lines running around the boot, especically in a targa car where you might be throwing spare wheels/tools/etc around in there. Dirt cheap because you just run a standard or 040 or similar pump in the tank and an 044 or 023 under the car.
The only thing I forgot is you still run out of fuel with a surge tank if you empy the fuel tank :O. It made it much further without surging though
There is a few options for the under car surge tanks.
1x pump
2x pump
1x weldon pump (far better than running 3x 044's, better than 2x 044's as well but more expensive)
All types are offered with -6 or -8an inlet/outlet fittings or 5/16ths welded on barb fittings ( the most common way to do it)
Also if you want one you'll also need to determine how much of the fittings you want me to supply with it.
The weld on tank fittings are included
-12AN couplings, pump inlet and outlet fittings are extra.
Ive done a few R33's but never made a jig to reproduce the mounting tabs.
So ill need to borrow an R33 for a couple of days to mount a tank and jig it up for latter reproductions.
Sounds good I will give Neil a buz tomorrow, is Zebra's old car still lying around Brad?
I already have one new 044 that I was going to put in the boot so I will use that. I like Fatz tank and set up I would just want the same as his but with the clamp for the second allready welded on an a cap on the other outlet. I will need the fittings for the tank to the pump and the outlet of the pump to the hose fitting.
I am also keen to talk to you about some door stuff and a breather tank set up for 26 covers on my engine.
Cheers
We only need to be told once... :P
I've still got some shit to sort out on my car quickly first before it comes back anyway, I'll give you a ring after new year and we can work out when you want mine back.
Still need to mod my exhaust manifolds... Stupid freaking bunnings for not having the right dremel gear... :(
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
