yeh the quality is amazing but quality also comes at a price and most people would just want a cheaper option.
anyway long story short, i didnt end up getting one of these bonnets. i put my cash into some other nice parts such as carbon 400r front lip, carbon abflug rear diffuser, new rims and tyres and also a nice HKS t51R :D
  • 2 years later...
Mmmmmm , I have the same delema, I bought the car with the Z-Tune bonnet on, so do I get rid of the Z-Tune bonnet, it is at least a 6 year old model ( if it is an original) and buy the new one with the water channels at big $ or have the vents blocked off permanently somehow.
But from what I can see of the new channeled Z/R bonnets the water will still run down inside the motor, maybe not over the motor, what about the electrics ect???
I want to be able to drive the car without looking out the window for rain or getting a long term weather report if I want to go away for a week or so. I do not or intend to drive the car that hard it needs this type of bonnet to cool the engine to save a second or 2, but they look good :)
Does anyone know of another solution to this problem without being a Smart A and saying "get a standard bonnet."If this is your only reply, dont bother!!
Either get a proper nismo ztune bonnet with water channeling or you could get some channelling built into your current one, or std, those are the options, my vented bonnet doesnt bother me cause its on a weekend or track car so i dont drive in the rain if i can help it, plus traction with my power and rwd is no fun, drive the navara instead...
Get a std bonnet..
Seriously though, your question was answered on page 1 of this thread. Get some Perspex or similar and some insulation or foam tape to fill in the gaps. You'll know if you have a leak even with a small hole.
Thanks,I did read the other suggestions and I will see if I can get something done. I will go for a permanent fix.
But I think if there are vents on a bonnet and your car is a daily , regardless of the make quality or adding channels or whatever, water will get onto your motor area and then everywhere else, water coming anywhere under your bonnet & wind = water all over the inside your engine bay. It does not mean it has to be pissing in to cause long term problems, just a continuous exposure to water will do it. That is why I do not drink the crap :no: .
If I do not want any water in the engine bay then I have to seal them off totally or as suggested , get a standard bonnet.
Since I do like the look and use it as a daily, sealing them off is my choice :yes:
Even if you get water on the engine its not a major issue a little bit of water wont hurt, but water in the valley will cause miss fires, a daily with a vented bonnet is fine with a genuine nismo bonnet thats what they make it for, so no major water gets into the valley.
If your just going to seal off the vents then also think about the pools of water youll get in the vent area which will also be annoying, been there done that.
Seriously get water channels built into it or get a proper nismo bonnet otherwise go std, they are the only options, blocking off the vents makes it annoying and totally gay
Finding someone to do anything different up here is a problem, got one quote $600, so I did it myself yesterday . It was a bit tricky with the bonnet still on the car and would be much easier if you take it off,
Bought a sheet of lite Aluminium as it is easy to shape, $32 from Bunnings and made a cover to go under ALL of the vents, sealed and bolted it on to the skin under the bonnet, added a hole in the front that is just to the side of the radiator where I will make up a funnel and hose that will let the water out without going on anything. Well that my theory :unsure:
I did leave it opened at the back just to see if the vents can still keep it a little cooler, this could cause a problem but it work fine if I just tip water in through the vents BUT I will have to wait until I fit the funnel and drive in the rain to check it out, maybe the wind factor under bonnet will force me to modify it, bloody hope not as it is on there to stay :unsure:
What sort of monsoons are you guys driving in.... I have a z tune bonnet and have had one for over 2 years without any issues at all. The only time i see a bit of water in the bay is when i spray it with a hose.
But rain I have never ever had an issue with.
They are copies and the water just pisses in and I do not like the idea of having water all over my engine etc if I get caught in the rain and the idea of not being able to drive your car in the rain is nuts :wacko:
I have a copy and water doesn't piss in with QLD rain. Each to their own I guess, but as I said I have had one for over 2 years without any issues at all. Only time a decent amount of water gets in the bay, is when I hose my car and even a genuine nismo wouldn't stop that.
But the ztune bonnet has vents right over the engine yes?
And the non genuine ztune bonnets have nothing to stop water going through the vents, right?
So how does your engine not get wet?
Pics???
The vents face backwards from the direction of travel and they aren't that massive, so hence why it only gets a little bit when you stop at the lights. A genuine nismo has the same vents, but has internal water drains to help guide the excess water away from the engine, but still has the same size vents, so even heavy rain would leave a few drops on the engine.
I think people get the impression that water just pours into the engine bay, when in fact it gets barely anything.
^^^ ahhh well that will mean a bit of rain gets on your engine, and your bonnet vents look a lot bigger than the z-tune ones as well. But in saying that, in mine the water only just goes on the front of the engine or between the radiator and engine. (Also I don't park my car in the rain.... lol)
If it is coming down all you have to do is stop at a traffic light and there is only one place the water is going as it runs through the vents,engine bay,motor and anywhere else gravity wants to take it.
My vents cover about 1/3rd from the front of the motor.
Even when washing the bloody thing and a bit splashes on the vent area the motor gets water on it ( I do not mean pointing the hose at the vents) and that is just a splash, not a bloody down poor while parked or sitting at the lights.
I have not driven in the rain yet but I cannot believe these copy Z-Tune vents would not get water in them even while driving , I know air comes out through the vents but strong enough to stop all of the water going through , I doubt it. BUT?
:rofl2:
i think the only issue is raining when parked and car's being washed. not to mention overnight moisture.
even then, would it make the engine bay that dirty?
how bout a standard bonnet with NSCA ducts?
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
