  • Replies 89
Posted Images
Well I think E36 M3s had a 300 Hp 3L all aluminium straight 6 twin cam with individual throttles and twin vanos/VCT .
Not cheap but if you could source parts or a wrecked one everything should bolt/plug in . I remember SK saying that they have virtually 50 50 weight distribution front to back which keeps them light and they handle real well too .
Keeping it in the family would be preferable but otherwise possibly a high CR NA RB26/30 ?
A .
A .
HA! :rolleyes:
Well picking the BMW up tomorrow getting the 328 diff thrown in for nothing. Total weight of car is 1240 at the moment without a motor but the carpet weights almost 100kg cos it's full of shit will post some pics so people know what I'm getting myself into. Also can anyone conferm a patrol sump could fit the rb
it will be ALOT less hassle to fit either a 1 or 2JZ motor.
Seriously consider this option before you get started on an RB25 install.
I'm sure you could sell your forged RB25 and get a manual 1j front cut for the same price..
but more for 2J
ps - here is one a guy on PF did - 2J in to E30 318i
http://www.performanceforums.com/forums/showthread.php?67260118-FREe30
Edited by GTST
In not interested in the 1j I'm after reliability so forged is the go patrol is rear sump so that solves my sump problem
1J is a better motor than the RB25 anyway. On top of that, the Toyota motors have the inlet and exhaust on the correct sides for BMW engine bays, which makes it easier to fit things in. On top of that, they don't have cross over inlet tracts, so you don't need to worry about engine height so much and don't need to bugger around with aftermarket/homebuilt front entry plenums. You just use the original plenum.
1.5J can be built up for not much more $$ and makes getting a 3L engine trivial, with less legality issues and other hassles than any RB2530 build.
Overall, unless you are starting with a free (ie you've already paid for it) forged RB25 and you're just looking for a car to put it in, it makes a lot more sense to rethink the project in terms of motors that are better suited, rather than just sticking to something comfortable.
If you're committed to the RB, go right ahead. But there is a better way.
OMG.................................................................................................................................................... LOL!!!!!!!!!
i love rb engines and i have one that i got for a bottle of jack i bought the coupe for 600 with everything but motor this build will cost less then 3 g. i can do all the fab work at the end of the day engine reliability comes down to the tuner and im not asking for mas power just around 300 and a forged rb will give me that. ill be putting a plenum on that iv fabed to lower engine height plus will get a diff sump to make it fit perfect. i dont know 1j or 2j engines but i know rb engines and will have no problem fixing it if it breaks thats if it does which i doubt. im very confident in my tuner to deliver results not cos he is a mate but because he is good plus he is helping me build this car so he will now what is in it and not in it. there seems to be heaps of 1j swaps i want something difernt and want a rb in my bmw coupe. i understand the 1j will be a better fit and more sorted but i dont like the easy option out i like fiddling and doing things differnt thats y in undertakeing this conversion
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
