Wrecking R32 4 door Gtst track car
Parts located in lower Blue Mountains Sydney for pick up or I can arrange shipping at your expense.
Happy to post up further pics as requested.
...Also wrecking an R32 Gtr so if you need any parts pm me...
Rb26dett rebuilt long motor $5,000
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1013.jpg
400km since rebuild by Boostworx in Adelaide
ATI 600hp Harmonic balancer damper & pulley kit
N1 water pump
HKS oil pump
Tomei oil gallery orifice
ARP Head stud kit
Cometic Street Pro 87mm MLS head gasket
Nissan full gasket set
HKS step-2 valve springs
R34 Greddy N1 Street Special camshafts, R34 CAS
Ported & Flowed headwork
Greddy timing belt
Precision adjustable intake & exhaust cam gears
Drive key, tensioner & idler bearing kit
87mm CP Piston kit - full block tidy up
Rb26 standard turbos $1,000
rebuilt with steel wheels
R32 Gtr N1 turbos $1,000
R32 Gtr Garrett -5 turbos, done approx 15,000km $1,500
Wiring loom for R32 Gtst Rb26dett conversion $200
R32 Gtr Power FC with hand controller $750
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1011.jpg
Intercooler 600x400x100mm and piping $300
BOV setup including stock Rb26 BOVs and return pipe $250
Intake kit including copy Greddy pipe to intercooler, twin pod filters $400
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1024-1.jpg
5Zigen 3”stainless steel turbo back exhaust $250
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1000.jpg
HKS split dump pipes $250
OBX tuned length manifolds $250
OBX tuned length front pipe $200
Stock Rb26 front pipes $150
Stock Rb26 exhaust manifolds and dump pipes $40 each
Intank Gtr fuel pump $150
Walbro 305LPH external fuel pump and 4L surge tank including 5m braided lines and Speedflow fittings $400
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1026-1.jpg
Fuel pressure regulator $100
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1023-1.jpg
Fuel cooler $40
550cc Siemen Denso Injectors, new O-rings, seals $400
Yellow jacket coil packs $180
Oil catch can 1L $50
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1020.jpg
Oil filter relocation kit and 30-row cooler, with Speedflow fittings $300
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1021.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1019.jpg
ASI 52mm dual core alloy radiator, Blitz cap, JC-project silicone pipes $200
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1018.jpg
Turbotech manual boost controller $150
Wilwood 4 piston Superlight front brakes with Brembo 324mm drilled discs $1,300
Includes three brand new sets of spare pads, bracket adapter kit and braided lines.
Stagea rear calipers and rotors $150
MDU Gtst suspension $600
Near new, fully adjustable, still under warranty
Greddy strut brace front $150
Custom strut brace rear $120
Nismo front tension rod link set $200
Bride drivers seat with super low rail $300
Some tears, would suit a track hack
R32 passenger seat, good condition $100
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1010-1.jpg
SAAS Steering wheel (no boss kit) $100
SAAS gear knob $50[/b]
R34 Gtt factory steering wheel $200
Tomei 300km dash $350
M's turbo timer $50
Apexi 2” Power Meter gauge $80
Autometer Sport-comp 2.5" boost gauge $50
EBCR 2” exhaust gas temperature gauge $40
AEM wideband sensor gauge kit $100
Apexi Multichecker (Engine check system) $300
Bolt in 4 point roll cage $500
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1008-1.jpg
Short shifter kit, brand new in box $80
Blitz R32 Gtr fibreglass bonnet $650
Top condition with N1 lip and aero catches
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_0994-1.jpg
R32 Gtr rear wing $150
Has a couple of chips
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_1002.jpg
17 x 8 rims, no rubber $500
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_0989.jpg
4 Door 1993 R32 Gtst shell[/b]
http://i236.photobucket.com/albums/ff9/fatzgtsr/for%20sale/IMG_0993.jpg
Non rolling, previously registered in Vic, suit track use $1000 or $1500 with bolt in roll cage. Shell is mostly stripped out except for dash.
Also happy to sell other parts from the shell including brake master/booster, clutch master, dash, door trims and switches etc. Just ask.
Pete
  • Replies 82
hey man what brand is the cooler? can you send me some pics of the cooler and the radiator..
thanks
Not sure what brand the cooler is
there are some pics of each via the links in the thread otherwise you'll have to wait until I pull the car apart over the next week or so :)
hey pete, do the wilwood calipers sit out any further than standard ones?
and how much meat on the rotors, any cracks or glazing?
Wilwoods appear to be about the same as standard, but come check them out... I'll even throw in a free i love chris easton tshirt if you buy them ;)
Blockasr32
Not sure if the cage will fit to a 2 door
Bride drivers seat/rail SOLD
Oil relocation kit, HKS dumps and yellow jacket coil packs SOLD pending bank transfer
Pics of Wilwood brakes for those who are interested:
They are in very good condition, no cracks, glazing or lip on the rotor. Appear to be in near new condition with plenty of meat on the pads (plus 3 spare sets!)
pete
hey fatz will the cooler bolt into a gtr and or do you have a 100mm thick gtr cooler flaying around
yea mate the cooler will bolt on with the piping that comes with it :)
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
