Hi guys,
I just changed my coil packs on my neo motor and just wondering if it is ok to leave the coil packs exposed (not putting back the long black rectangular cover panel), I have seen a lot of engine bays with exposed coil packs but my flatmate thinks there might be risks of water/ moisture getting in from the bonnet edges and splashing up from the road while driving. Are there many of you driving without this cover on and anyone see any probs??? The reason i wana leave it out is for easy quick maintenance swapping out the coils n spark plugs when the need arises.
https://www.sau.com.au/forums/topic/385934-rb25-engine-coil-pack-cover/
At the track it's a good idea to take it off to stop the coils from being cooked, but probably unnecessary to do with street driving. I know I leave my cover on when not at the track.
The nissan engineers know best . . .leave it on
Is that why neo coils invariably fail...since their engineers know best?
I have removed the coil pack on both cars and have driven that way for over 11yrs and 6 yrs with no issues after replacing the factory coil packs with splitfires. The heat seems to be a factor in killing them so why not take it off.
It doesn't really matter either way with normal driving, I've run my Neo without for over half a year, no issues. Some people say you can be defected for running without, blah blah. I suppose it's whatever you feel comfortable with.
Indeed, I've never heard any other engines have as many issues with the coils as the RBs... Oh well at least it's an easy swap.
Oh thanks guys then I guess it is ok to leave it open, in fact it seems like a better idea as you saying the heat kills coilpacks, but what about water/ moisture going in?? And possibly puddling up in the coil pack cavity as well?
The cover is vented thru slots on the timing belt cover and air flows thru them and out the back of the coil cover near the fire wall, , , beats crud dropping in the motor when you change spark plugs
Edited by StevenCJR31
+1 for leaving it off. keeps them cooler as well as actually keeping them free from moisture. the reason being that while moisture may get the them a bit easier, it can also get away from them easier. for example, if you degrease the engine, the cover doesn't seal that well and water will get in around the coils (know this from experience). with the cover offer, after a bit of driving around most of the water will be gone. leave the cover on and even after a few days the water will still be there because it can't evaporate easily (well it does, but it just stays under the cover as steam and then into water droplets and only a small amount of it actually gets vented - also know this from experience).
as for crud dropping into the motor when you change your plugs, if you are stupid enough to pull the plugs out with crud in the valley then you have no-one to blame but yourself. anyone with half a brain would clean it out before hand.
The cover is useless for keeping out moisture/dirt anyway, the holes for the bolts to go through leak and there is a big gap at the back as well. You need a substantial amount of water to cause any problems, you won't get anywhere near enough just splashing up from the road.
I've had mine off for about a year now, no problems.
i dont think they have done that bad a job. These cars are usually between 12-17 years old now. N for what they do (and how much more we get them to do) n how well they hold together is quiet an achievement.
[hyundais cant even seem last 10 years at 100hp out of a 2litre!]
its a part that breaks down over time. perhaps particularly in the aussie heat conditions (that they werent designed for).
N for what its worth iv run the cover off for 2 years with no probs (on spitfires). Tho got a custom vented one to go on so it looks a bit more kosher for the fuzz. (its all looking pretty modded under there now so dont want to give the boys an excuse if they arent happy with my style...)
Edited by jjman
Stock coils are still the best, they just don't last for 15 years, they're a perishable. If I had a choice between new OEM coils and Splitfires for the same price, I would go the OEM's.
Edited by Hanaldo
I got brand new OEM's for half the price of Splitfires ;)
u for real? whys that?
splitfires are known to be able to perform better, esp under higher stresses/hp.
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
