Hey all I just ordered a set of 18x10 + 25 and me being the dick I am assumed they would fit my tyre guy reckons im going to struggle fitting them has anyone had experience with 18X10 under r32 GTR? If so what's needed for fitment and what tyres would you recommend?
cheers
Sam
https://www.sau.com.au/forums/topic/386195-r32-gtr-fitment-help/
Yeah id need at least 10mm can you get 10mm bolt ons? What's so bad about slip ons personally i don't trust slips but are they really that bad?
10mm will put u same as mine 18x10 +15, wouldn't go more than that
I don't think 10mm comes as bolt on only 15mm onwards
Just make sure u have enuf thread once the spacers are on otherwise will need to change ur studs to longer ones
i run 255's on my 17x10's, slight stretch was needed.
to my knowledge,any tire that needs stretching will effect your grip.
my 33 sticks down nicely but it can still spin the rears when i want it too haha.
Good luck with the fitment.
Edited by S1DWYSR33
Even with 10mm spacers still doesn't fit fml...id need at least 15 but then id be struggling to fit rubber...so the moral of the story is don't be a dick do some research first thanks for info lads=)...anyone want a set of 18x10 XXR 521s?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
