  • Replies 52
not sure if people realised but you can actually change your Origin name to match your forum name
now i know some people may not want to align their names up but someone might
enjoy
http://www.origin.com/au/change-id
You've fked up the settings then.
I cant remember what it is, but one setting will cause that constantly. Ill try find out which one
The problem is related to the TS overlay plugin
Go and disable that somewhere in the settings, and you'll be fine. Had the exact same thing.
oh oh sorry i didn't mean g15 overlay
umm
In Settings-Plugins, I've only got the top two plugins ticked
I think I had DirectX plugin ticked before (cause I wanted to figure out whose voice was whose while playing) and that crashed it.
Pretty sure that's the one I was talking about...? Not sure. It's christmas day and i'm a biut drunk
umm
That one worked :) Thanks.
Funny it only started happening about a week ago. Prior to that I never had an issue.
Edited by Cozi
  • 7 months later...
Who's keen for a Beef3 night?
I'm yet to play this game in a team using Vent/Teamspeak. I can't help but think that would assist greatly in my pwnage.
Could someone please give nee the low down on what the f**k I need to do in order to play this game now? I bought the special edition or whatever, karkand thingy...didn't play for a while and now there's like no servers :(
Check your filters, Troy. If you have one wrong filter selected it can get rid of all the servers. Try removing all filters and see what happens.
I'm keen for Saturday night. One caveat though, I often have to go AFK to look after my daughter and/or wife.
You have to own BF3 bro!
And you want to help me with DayZ? dfarq
Positive it's not the filters. It's either as if all the servers I played on previously vanished when I downloaded the huge patch recently, or I have to now also purchase the most recent expansion pack to continue playing as I normally did.
Seriously dude. Seriously. Just you wait. Seriously.
(I've got nothing)
(I've got nothing)
as the others said there must be something wrong with your filter settings, can you post a screenshot of your server browser settings?
There are still lots of base game & karkand servers around. Though I am liking close quarters
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
