I'm trying to decide what throttle body to run on a Plazmaman plenum.
It is my RB25 GTST and aiming for 300 rwkw.
I am assuming the stock throttle body will choke the engine a little and would a 72 mm be adequate?
I know Q45 bodies are around but I think they need an adapter flange welding on?
I don't want to run a 72 mm if it will lose me power.
https://www.sau.com.au/forums/topic/386403-throttle-body-size/
e.g. Proengines as per above - 364kw with standard t/b (can't edit my posts atm).
Yeah but you might have got 374kw with a 90mm TB.
I just don't know.
I'm thinking of settling on a 72 mm TB. My pipe work is all 2.5" so can't see 72mm being a restriction as such.
My main issues is bolting it on to the Plazmaman. I know the Plazmaman takes the stock one, and I know the 72mm fits the stock plenum. The 90mm TB's need an adapter I think? So the 72mm would just conveniently bolt on w/out a need for an adapter?
Y r you wasting money. Heaps of rb25s out there making over 300 with stock tb the amount of restriction I would make is nothing plus you will loose some mid range power
How is it going to lose mid range? I think you mean throttle sensitivity?
Stock throttle body will be fine. Saw in an imports magazine the other day a silvia with an RB25 and 500+ hp with a GReddy plenum and the adapter to fit the stock throttle body. No problems with stock throttle body unless your building a show car or making rediculous power
Thanks for the responses.
There are some calculators on the web in places.
I might play around with them at some point, but I am thinking to just stay stock, mainly for cheapness and modulation.
Calculator
  • 1 month later...
  • 3 months later...
Calculator
Interesting, that calculator suggests 72mm when I enter my engine variables. I also run a plazmaman plenum and interested in trialling the throttle body. Hoping they will do me a return policy on one in case the performance doesn't match their asking price
I went will the Plazmaman throttle body for looks and that the stock NEO throttle body is about 8 foot long... Haha... I chose to stay with a near stock size tho of 66mm... I guess for street use the throttle response was important...
Get this straight.
Throttle response will be greater with a larger throttle. This is only because a larger throttle will give you a more rapidly increasing throttle flow area as you open it. ie, more mm2 of area opening up per millisecond.
Throttle controllability is maximised with a smaller throttle - well, at the bottom end of the opening range, anyway. If you need to be able to modulate small openings, then you need a smaller throttle rather than a larger one, for the same reason as given the he above paragraph. A larger throttle gives yuou bigger changes in open area per degree of rotation of teh shaft - ergo, less sensitive.
Apart from any restriction put up by the throttle at WOT, a different throttle cannot really cause a loss or gain in midrange power. If it is small enough to cost top end power, then it will cost mid range a bit too. If it is so big that it is not any restriction at all at the top end, then it will be even less of a restriction in the midrange.
/obvious.
So, does that mean you have seen someone leave everything else the same except change to TB and realise a change for better/worse or no change?
I understand people make perfectly good power with a certain TB. The reason I am considering it is the TB is obviously sized for a certain lbs/min of air. When you go from 110rwkws to 310rwkws I dont think its out of line to wonder what affect that has on pressure drop through the throttle body....or more to my thinking what its doing with regards to the velocity of air through it and in turn the pressure drop you have when it goes into the larger plenum and cylinder filling
So with what your saying, the smaller throttle body is still better for daily driving and throttle control on street?
I did a fair bit of asking about all this when I bought my plazmaman kit, but happy to hear others opinions....
If you get up to the 300rwkW area (or possibly even less) then I have no doubt that you'd free up a few kW by putting a bigger TB on. If you calculate the gas velocity through things like the TB at the temperature and pressure of post intercooler air you'll be pretty frightened by how fast it's going (compared to industrial gas flows where we try to keep stuff below about 30 m/s if we can, to prevent excessive noise and pressure drop). The very high velocity leads to high pressure drops along lengths of pipe and through fittings and valves (like the TB). Upsize it, lower the velocity, significantly lower the pressure drop, gain a psi maybe, which is a psi that the turbo doesn't have to make, and drive that the turbine doesn't have to provide and hence less back pressure on the engine.
But you have to realise that the cross sectional area increases with the square of diameter, so you don't need to go from, say, a 66mm butterfly all the way up to a 90mm. That's 85% more flow area, which you probably don't need. But what you certainly don't need is the first degree of rotation off closed to give you 185% of the flow area that the original TB would have, if you're trying to drive it normally.
When you say that a TB is designed for a certain lb/min of air flow, that's not quite right. When we design a valve to act as a flow control valve, we start out with a few numbers. Those are, the mass or normal volume rate of the gas, the starting pressure, and the amount of pressure drop that we're willing to accept over the valve when at full flow and 100% open. The designer has freedom to choose that last parameter based on his needs. But importantly, when boosting up an engine, we are not just changing the mass rate of air, we are changing the starting conditions as well. Let's say we double, or triple the boost from the original 8 psi or so. At the same gas veloctiy we're flowing a lot more gas through the valve straight away. Even if we end up with the same pressure drop as the original design, we'll still be flowing bucket loads more air than originally. My point here is that control valve design is complicated - and the application in question here, being automotive compressed intake air, makes it harder to mentally estimate what is going to happen when you make changes (say to boost). So one of the best guides to what to do, is to look at other's experience. That's an engineering basic - copying those that have been successful before, avoiding what those who have not been successful have done. Use their experience to decide which numbers become important.
Absolutely. I wouldn't be tempted to go much bigger than 80mm under any circumstances where the car is still supposed to be a street car. Probably even smaller.
  • Like 1
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
