im assuming that the guy who originally put the grounding kit on my car did it incorrectly as the gear changes just take for-bloody-ever. if anyone can point me to a guide for the proper bolting locations for this kit, itd be appreciated.
i didnt realise how lethargic the nissan auto was untili drove the boxster this week..
ta
Edited by Deep Dish V35
The grounding kits do ABSOLUTELY NOTHING. Don't listen to a word anyone says if they say they do. I have put them on 3 of my previous cars and my V35 just in case they actually did something, but they don't.
And seriously, you are comparing a new (presumably dual clutch pack) $100k+ Porsche gearbox to an 8 year old V35 gearbox? WTF?
I have always wondered about the effectivness of grounding kits. I put one on my old J30 maxima years ago, and it did absolutly nothing. At the time I figured it was just a money making scheme for those who were too lazy to clean their factory ground points, and since I always kept connectors and ground points clean, it didn't do anyting for me.
my car comparison was simply from a point of selecting a gear in the V35 and then waiting multiple seconds for anything to happen. i have to select at 4000rpm so that it shifts by the time it gets to 6500rpm....,
its just that when driving our 2008 porsche, tiptronic is worlds apart in effectiveness. not so much the shift speed, but the shift delay..
Does the boxster have a DSG? If so, then it is very unfair to compare it to any standard auto.. not just the V35 RE5.
I have to disagree, I put one on my V36 a while ago and it definitely sped up the speed of the down changes through the paddles. If it makes any difference to power (which I doubt), it would never be enough to be noticeable and it didn't seem to make any difference to the up changes. One other thing that I have noticed is that it doesn't seem to hunt for gears as much when driving in traffic, in full automatic, previously the box seemed to take a little while to decide which gear it wanted and would sometimes stay in a lower gear for too long. This simply makes it feel a little less jerky when putting around at low speed.
If you believe that they do absolutely zero, then that's fine, but I have noticed a definite difference. Now whether it was worth the $80 or whatever it was, is another question.
Edited by Alkatraz
you need a shift kit, at 4000 when you shift, the trans will shift at around 4200 or less
its not a shift kit thing. its something electrical. maybe even something in the computer that could be reprogrammed with the right scantool. i dont want it to throw itself into the mext gear and chirp the wheels, just begin the gearchange process when i push the selector.
looks like i'll have to post a video of how long it waits before changing gears. i can literally push the selector, turn the volume up on my radio, then put my hand back on the steering wheel before it does anything at all.
they all do it, they are programmed to be sluggish.
mine did the same thing also.
also the position of the throttle makes a difference. if you full throttle the car, no matter where you select to change gear, it will change at redline (or close to it) again, another programming thing by the TCU
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
