http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi_06_-_guidelines_for_light_vehicle_modifications_nov_2007.pdf
page 3 - not sure how an engineer doesnt know that
call autosport engineering in kirrawee for engineering your conversion
  • Replies 117
yeah i read that but the new laws are changing the capasity and nobody knows what is going on but rough guide lines are out there. ill give him a call tomorrow and run both conversions past him thanks for that info mate.
so sr is the go its so much easier and will cost less to engineer but im not fussed i like sr motors plus im not going for record power. so i pulled apart the sr today and shit my self when i fould this in the sump
which luckly only caused this
oh and 2 missing oil squirters but thats ok because forged pistons are only 500 bucks cheap. and ill take the squiters off my 25 block as im positive they are the same. on better news installed the radiator today all looking good there. iv been looking out for a set of recaro seats i think it would add a nice touch the to bm as im still wanting to keep some jdm looks thats if they pop up cheap enough.
So last day before I go back to work so I got stuck into finishing the inside. Wired in the push button start looks mad also installed a switch for the reds so I can rid of the ignition barrel. Hard wired the fuel pump with kill switch and left it wired to airbag incase of accident. Stole the cd player out of my bros car terms and conditions of me installing it haha. I forgot how good the stock BMW sound system is all rockford gear kicks ass. Why spend hunderds on pioneer gear when this is better tip for guys looking to upgrade speakers. The pump is noisy when under the back seat have to look at trying to muffle out the sound a bit any tips? So far build has cost me
Car $600
Wiring $14
Push start button $12 (jay car)
M3 LSD diff $300 (traded in my old one)
Sr20 traded for rb30 forgies had no use for them anymore thanks DVS jez got the whole bottom end for 200 originally
Sr20 ally radiator $100 ( brand new)
Everything else I either had or was given to me for free by mitch at Reno wreak top bloke he is.
Things left to do inside
Front seats if a can afford recaro otherwise I need drivers seat
Re do roof lining was saggy $150
Fit glove box
Install door cards and install drivers lock assembly (free)
Put all covers back on and give it a good clean
Exterior bits left
Lights all around
Fit bumpers on doors
Give the whole car a decent buff
Repaint rear bumper and radiator support
The go fast bits left
Fit new suspension
Sr is stripped needs a skim and pistons then reassemble
Make motor mounts and gearbox mounts
Fit the m3 diff
Custom drive shaft
Wire it all up (DVS jez will be doing that)
Do piping
Exhaust
Tune
I'll be running a s15 turbo with a set of 550 injectors going to pust it to 340hp is possible
Then engineer cert and rego then the best bit drive the fck out of it but a long way to go yet
Pics will be up later
so havent done much dummy fitted the motor and wired up a cd player. will have to make a custom sump never relised the sr was so tall but thats not to worry. a few photos of goodness.
ill be using a rb20 box behind the sr i just need a bell housing if anyone has one?
So not many updates busy moving houses iv put all the trims back together just waiting to move so I can start again also picked up a running motor off a forum member which I will use untill I build the one I have hopefully with the more money coming in things will happen faster then planed
Rito progress finally iv now picked up a sr bell housing to run on my 20 box iv also got a vct sr20 as well I'll put new bearings in it and I'm happy. I'll bolt it together then install it then while I'm making mounts jez can wire it in I'm hoping it will be running in a month then I just need a few little things. I'm going to run my old td06h-20g turbo on a mani I'll make so 260kw is very possible will be one fast BMW
Edited by Bsa
Ok so with much more research iv found that BMW e36 can suffer from terrible fuel starvation so iv decided to run twin pumps one on drivers side one on passengers side twin walbros I'm fairly sure that will sort any fueling worries may keep the sr pumping a lot longer
BMW fuel tank sits under the rear seat so the tank is basically in 2 halves with a small passage joining them so the one pump both fills theother half to equal the fuel level so whenpulling high gs around corners you have a high risk of the pump becoming open to just fumes. So by adding a second pump to tge passenger side of the tankyou almost have no chance of missing fuel pickup. It's a common upgrade for m3 bmws as there are 2 openings and cradles to hold fuel pumps. If you look up BMW e36 twin fuel pumps it gives a much better description then I just did
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
