Ok so I hear some people say that the RB benefits from positive crankcase ventilation and some say it does not?
So should you just let it breath 'oh naturale', or does it benefit from a bit of -ve pressure to suck out those fumes and blow by?
FYI I couldn't give a monkeys about emissions laws it is purely for the health of the engine.
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/
Yeah man I'm in the same boat. I got a GTR, a little off topic but i want to set up a oil catch can so I don't know if i should block the pcv valve and run the catch can or let it breath and run a catch can OR block/ unblock the pcv and run no catch can. (stock set up)
I've been told people just block it to keep the revs down at idel and numerous things about a RB26 not creating alot of blow by to really worry about any problems. I guess the only reason why it breaths in the first place is just for emission laws.
But if you block it, all that pressure has gotta go somewhere... ie. through seals causing oil leaks. Out the dip stick..
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6168426
I am making a venturi set up attached to my dip stick tube to remove pressure from my crank case. This is a stop gap plan until I can get the engine out to do the proper oil control - smaller oil restrictors and better drains etc. There is a theory that the "drain" some people put at the back of the head actually acts as a breather for the sump and that excessive pressure build up in the crankcase helps tp prevent the oil from draining from the head.
If it works I'll post up pics etc
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6168959
Was told by a very experienced RB specialist to leave it plumbed in. His 700rwhp RB certainly doesn't have any problems with it...
Sure but does he run it through a catch can before it goes to the intake?
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6169560
Doesn't the RB crankcase breath through the head with the stock set up? I thought that was the point of the breather system on the rocker covers. I understand that gases coming from the bottom end are competing against oil trying to flow back in the opposite direction, but otoh if you are producing a load of gas then surely you have a busted piston ring at the very least?
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6169570
Here's a thought. You go from idle to WOT with the recirc system. It puts the head under a bit more -ve pressure compared to idling, the gases in the bottom end try and equalise pressure and so flow up into the head, but this is right when you are wanting to stop build up of oil in the head and that oil is trying to drain down against the flow of gas up caused by your extra -ve pressure? Surely better to leave the head just at atmospheric pressure and the system open?
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6169575
closed throttle is when you have the most -ve pressure in standard form as its sucking through the intake manifold, once you go past 0 boost the pcv valve shuts and its sucked through the intake pipe (high flow but not much vacuum).
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6169806
Doesn't the RB crankcase breath through the head with the stock set up? I thought that was the point of the breather system on the rocker covers. I understand that gases coming from the bottom end are competing against oil trying to flow back in the opposite direction, but otoh if you are producing a load of gas then surely you have a busted piston ring at the very least? "
No. I have read the 40 page oil control thread twice
http://www.skylinesaustralia.com/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/page__hl__sk+oil+control
and it is a problem suffered by others with a new or old engine. It only manifests itself with sustained high revs therefore really only on the track. I had it with my RB25DET and now again with the RB30DET (yes I should have learnt).
You are right about the breathers on the can covers but when the head fills with oil they just fill the catch can with oil (and blow it out elsehere as well). The problem is thought to be worse with RB30s.
There is always some blow by and especially at high boost and revs and the action of the crank is thought to make things worse.
So yes you need to keep your breathers and preferably run them through a catch can and then into the intake for a street car.
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6169854
Hi guys - for the second time (I should have learnt) I have installed a catch can and blocked the PVC valve. Both times I have. Loan the front crank seal. From now on I think I'll be leaving the PVC valve plumbed in.
It seems likely to me that the blown seal is from too much pressure with the valve removed. Any thoughts?
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6187716
I ran a hose from the catch can to the intake pipe before the turbo - I gather this is not what you mean by atmo?
I seem to be the only person on SAU complaining about a blown seal, other people seem to have their dipstick blown out. Poor me.
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6187743
Ok lets firstly dispell some myths..
All a "catch can" does is catch oil.. requirement for most racing categories (must hold a certain volume) so you don't spew fluids onto the track. Useless in a street car.
In a street car running a plumbed back system, you need an "oil/air separator" which is kind of like a catch can but has strategic baffling to scrub the oil vapour from the air before it is returned to the intake stream.
You can run a "catch can" AND an "oil/air separator" and then plumb back to the intake. For a stock street car this is overkill, only a separator is needed to scrub those nasty oil vapours out. For a modded street car with bigger turbo, making reasonable power and gets beaten up on then the catch can and separator setup would be beneficial while remaining legal.
If you block the PCV valve then must also block the return to the intake pipe. Basically, vent cam covers to catch can and then vent to atmosphere (those little filters you see on top of catch cans). I also vent my dipstick to the catch can to help reduce oil stuck in the head.
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6187789
Did you leave it plumbed to the intake?
If you block the PCV valve you HAVE to run atmo..
Is that so? I've see a few set ups with the PCV blocked but the two ports on the rocker covers routed back to the intake either by way of a catch can or not? What's the problem with taht?
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6188175
Your AFM wont be metering the air that is drawn in through the catch can vent - leaning the engine out.
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6188183
Back to what i believe was part of the original question and what i would like to know, is it better to use bigger breather hoses to get more out faster than standard, i have mine plumbed up in the factory configuration but i use a line from the cam cover that does not have a restrictor in it like the factory line does, it then runs through a catch can filled with stainless steel wool as a filter and then back to the intake pipe, is this better/worse/no different to have the restrictor in the line?
https://www.sau.com.au/forums/topic/386750-lets-talk-pcv/#findComment-6188330
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
