It's no different that the stock set up in that regard though.
If your venting the catch can then you will have air entering the engine the engine that is unmetered.
Best solution when removing PCV is to run both rocker cover breathers to a sealed catch can and then a single line back to the inlet pipe.
That's what I thought but it looks like It's creating enough pressure to blow the front seal?
IF you've pumped the head full of oil then the there is no path for the blowby to release pressure from the sump - usually this is when dipstick pops. Not sure why your front seal is failing though. How hard is it to remove your dipstik?
Anyway the fix will most likely reduce the amount of oil in the head - ie smaller restrictors.
That is the best setup when keeping the PCV...
If removing the PCV best to vent atmo...
I wouldnt say that the dipstick is stuck or hard to remove at all.
I don't really care about keeping the PVC or not - I just thought it would be better if I removed it.
Is there any benefit to keeping the PVC and most of the hoses from the factory, but install the catch can beetween the exhaust-side rocker cover and the inlet before he turbo?
I guess the immediate other option would be to remove it altogether?
Er if the catch can is venting to atmo then it is venting to atmo and not the intake!
That is the set up which is being criticised for sending unmetered air into the engine. I was saying that it does the same thing as the OEM set up except the PCV on the intake cam cover in blocked and the oil drops out in the can. If it send umetered air into the intake then so does the OEM set up!
Well you still get oily air being sucked in off boost so it is kind of half-arsed solution.
What? If the catch can is plumbed back into the intake AND venting to atmosphere then you will be drawing unmetered air in through the vent and into the system. If everything is plumbed in, you can't get any unmetered air going in. Where do you think this air is coming from??
Where was I advocating venting to air AND plumbing back into the intake?
Maybe I got this wrong but the solution where you block the PCV valve then keep the other side plumbed into the intake via a catch can (which is closed), was criticised as allowing unmetered air into the system and someone said you have to just let the catch can vent to atmo or it screws everything up? Can't be arsed going over the thread to find what was said.
See, I was thinking thy the sucking pressure that the PVC gives off-boost would be offset by the draw from the turbo (not necessarily pressurized) when plumbed back before the turbo.
I have seen pictures above which keep the PVC by having a t-piece near the PVC with one side going to the rocket cover and the other going to the catch can. I am guessing that this would be inefficient as the PVC valve would draw some air from the can rather than drawing all it's air (and vapor from the rocker cover)?
You didn't, someone else did.
I don't understand where you think this air is coming from? The stock setup is a sealed system. There is no unmetered air in the system.
nope, at idle the intake pipe has very little suction, if you put a gauge on it you probably wouldnt get any vacuum, whereas the plenum has heaps due to the throttle body being shut. obviously the closer you get to 0 vacuum in the plenum the less it would draw through from the intake side, until the pcv shuts as soon as you hit boost then it starts flowing the other way if theres any blowby.
@hanaldo, he doesnt think theres any unmetered air coming in, someone else implied that and has confused you :thumbsup:
has anyone noticed on the exhaust side of the head (RB25-RB26)
there is a threaded plug that can also be used asa drain back to the sump similar to the rear head drain.
depending the what exhaust manifold you have on there it may of may not be accesible. on my 2530 there is plenty of room to do this. just need to get around to finally doing it.
Hi this is how mine is setup works great large hoses from r/covers and smaller hose to turbo inlet catch can full of coarse stainless steel wool and pvc stock
Back to what i believe was part of the original question and what i would like to know, is it better to use bigger breather hoses to get more out faster than standard, i have mine plumbed up in the factory configuration but i use a line from the cam cover that does not have a restrictor in it like the factory line does, it then runs through a catch can filled with stainless steel wool as a filter and then back to the intake pipe, is this better/worse/no different to have the restrictor in the line?
I used to have my breathers vented to Atmo with the PCV blocked but after a while i was getting blowby and plumes of smoke out the exhaust at idle, and taking off, and backing off.
I was advised to put the PCV back to stock, and have never seen another cloud of smoke since.
The setup i have now is, Stock PCV, Breathers vented to Atmo VIA a catch can, and no turbo inlet pipe.
As someone mentioned, i just dont think the turbo inlet has enough vacuum at idle to sufficiently draw the vapours out of the head, if it did then the PCV wouldnt be there factory.
  • 10 years later...
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
