Adrian - what do you mean by A & S series?
See you Wednesday!
well your earliest Skyline wouldnt that be something like ALSID? then the GT-A and GT-B they are S54's ?
i will run this past you again on Wednesday night tho
Going to be looking at a R31 sedan today. Only going for 550 bucks, exterior looked very clean, but I haven't yet got to see the interior or engine bay/listen to it.
Either way if something is wrong with it, i'll pick it up anyway because it's only 550.
Stupid phone, i replied to this days ago, but it didnt stick...
how did you go, end up getting it?
hey guys
does anyone know if a r30 manual pedal box fit in a c210?? or be close enough? stuggling to find a c210 one
cheers
Not sure, not having tried but i dont imagine they would be far off? redrill firewall perhaps.
Cheers
Jason
As much as I wanted to, in the end I didn't due to space restrictions.
Starting my full time job this coming monday (Apprentice Butcher) so plenty of opportunities will arise soon.
hey guys
cheers
I don't think you need the whole pedal box for a manual conversion. I just exchanged the brake pedal and hung a new clutch pedal off the auto pedal box when I did it.
With any luck the R30 clutch pedal is the same.
C210 L24E
Injector plugs have been removed, how do i know that im connecting the right pne back to the right injector?
Is there a way to find out?
I'm told these are sequential injection ie one cylinder at a time not batch fire.
They should only reach where they are meant to go
if the loom has been unwrapped, you will probably need to check colour codes from the ecu and check out the schematics
C210 L24E
nope.. "sequential injection"...
it does not have anyway to tell what cylinder is where, except when it fire ( coil output )
look at my MR30 pictures here,
http://noddle.customer.netspace.net.au/MR30/
Nigel.
  • 1 month later...
  • 1 month later...
I have become the owner of a 72 C110 4 door 240k.
it has come with a L28 fuel injected 5 speed. link ecu.
the body is great and paint is in top condition. ill throw some pics up soon and start a build topic.
soon to get an RB26 single turbo set up and some JDM love.
ideas and any help with suspention diff brakes mods would be great.
are these a Rare car??
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
