I THINK the front was a 24mm adjustable and the rear a 20mm fixed? I'm not 100% sure as it was customer supplied but the front was an adjustable bar.
I personally like the idea of the (F) 27mm fixed and ® 22mm fixed if it was my personal street car.
The front would have been a 24mm; BNF24Z
The 27mm BNF27Z is recommended for motorsport only by Whiteline; it's a very big increase. I think on the street you'd probably end up with too much understeer; especially in the wet.
The feedback I have had from the 24mm bar is excellent
Thanks,
Not sure if I need it adjustable, though they seem to be the same price as non-adjustable.
Are these bars protected from corrosion?
The adjustment is very nice to have, you'll likely set and forget, but for no extra spend; it's certainly nice to be able to finetune to your own taste and to the behaviour of your coilovers.
I've delivered well over 60 sets of Whiteline bars to people on this forum, and I've never had a complaint about the quality. I've fitted several sets, and the fit has been excellent. I personally inspect everything prior to shipping, and I've never found a fault yet.
They are powdercoated in a Silver/ Blue metallic, and as long as you are careful when fitting, the powdercoat will provide excellent protection against corrosion. It is flexible, but will take a knock without chipping; like a painted bar will.
I notice you're UK based, so I can't help you with a Group Buy; but if you have any questions, feel free to shoot me a PM
Cheers, Dale.
Thanks for the input, if they're powder coated I will have no issues with corrosion.
Yes, I am UK based so not really an option for an Australian group buy.
So possibly 24mm front, 22mm rear.
I use the car mainly on the road, not on the track.
So no need for Motorsport-Type sway bars.
Also I want to maintain a somewhat comfortable overall experience, especially with the poor roads in the UK.
Sounds like you have roads much like most of ours, you won't go wrong with those choices.thumbsup.gif
FWIW I have 24mm adjustable on the rear and 24mm fixed on the front, and I wouldn't have less stiff bars than that. Rears are set to the softer setting, not that it's hugely softer than the harder setting. Car is not tail happy, so I think it would be more understeery if I'd put the 22mm on the rear. This is an R32, which is what, 80(?) kg lighter than a 33. I'd recommend not getting a 22mm for the rear.
I hear you, but in the UK they have the usual potholes plus(to make matters worse)
Speed-Bumps and Speed-Tables.
Potholes are from mere neglect, but the Bumps/Tables are just evil ..
Often the local council is not in line with regulations and the Speed-Tables are way too high.
(You can tell by the impact markers of sorry oil pans)
That's why I don't want to lower my car much (have not decided on the right coil-overs yet)
I wonder where all the tax $$$ go ;)
As for the sway bars, I will see that I can find a distributor in the UK.
Good nite!
Speed humps and tables have no effect on sway bars, or more to the point, sway bars have no effect on the car's suspension when hitting a bump with both wheels at the same time, a la speed bumps and tables. And I wouldn't be choosing sway bars because of the presence or absence of potholes either. If there are potholes in a road, you probably won't be driving hard enough for stiffer sway bars to cause you to go off line anyway. Here in Australia we have many country roads which have a lot of broken bitumen, wrinkled bitumen and tree roots causing severe short pitch undulations in the surface. It is under these conditions that stiff suspension, and in particular stiff sway bars on top of stiff spring rates, can cause the car to be too jiggly to hold the road well. This because you often hit such an lump with only one wheel at a time. Despite this, I still vote for the 24mm adjustable rear bar as a better choice than the 22 fixed.
Thanks,
I was just elaborating on the pothole situation, had nothing to do at all with me buying swaybars.
And I hear you on 24mm....
Hitting one of these obstructions with just one wheel is always a pain..
So when choosing the new coil-overs I will take road conditions into consideration.
Any suggestions?
Edited by Torques
Hi,
I don't know ...
And what are HD-Links anyway?
I just started to look at my car's suspension, so not familiar with all aspects of it.
(I did the engine, so now suspension)
Do the kits come with the option of HD Links?
If so, get them.
I did that with the Whiteline RSB on my Subaru Forester - greater reassurance.
If so, get them.
Hi Terry, they are definitely a worthwhile upgrade,
No rubbers to wear out and get squeaky, miles more responsive, it's win all round.:thumbsup: They're completely service free and quiet as a mouse. Even on OEM swaybars they made a difference on my car, with Whiteline bars even better.
I also happen to do killer prices on these.:whistling:
Hi there,
Hmmm .. that looks interesting, must be worlds apart from the standard linkage.
Geez it looks already like one of these small jobs you do on your car and
then your find yourself replacing 90% of the suspension while 'at it' ;)
Hi there,
Once you have the Whiteline bars, this is always something you can add at a later date.thumbsup.gif
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
