ok boys and girls
car has been booked in with the tuner and should be ready within a fortnight.
Current mods:
- PFC
- -9s with 18psi
- 3.25" front pipes
- 3" cat
- 3/3.5" catback
- Stock injectors and AFMs
made 270rwkw @ 15psi with a shitty compliance cat and exhaust on it... is prob making around 280rwkw at the moment
new mods (the major ones) will be as follows:
- Haltech ECU
- Haltech boost controller plugin
- Twin Intank bosch pumps
- 1000cc Injectors
- Aftermarket fuel rail
- de cat
- 3.5" catback
- EFLEX Tune (allows to run a mixture of both 98 and e85)
Plan is to chuck it on United e85 and wind the boost up to around 28-30psi and see what she makes
hoping for around 380kw
Stay tuned!
Umair
https://www.sau.com.au/forums/topic/387645-stock-rb26-9s-e85/
i think it will go bang!
no offence, but i doubt that you'll be able to push the -9's past 350rwkw (you'll probably have boost control issues especially above 24psi)
especially on a stock motor, i think you'll find that it'll probably spin a bearing
28-30psi standard engine/head gasket etc?
PT did another stock RB26 with -5s which made 410kw and is holding strong so far...
we'll see... if it pops its just an excuse to rebuild :thumbsup:
lets see what happens...
gotta push the boundaries every so often
Cool, do you know the size at the turbo end? Most seem to be 2.5 or 2.75"
Interesting to note Unigroup to like Link's whereas Powertune seem to like Haltech's. Each to their own I guess
I'd say it would be 2.75"
not too sure to be honest
those front pipes look chunky :)
are you gonna run the stock intercooler for that boost/power level?
yep if you boys want some let me know... they pretty good value too... think they set me back $300
running the stock cooler... was going to upgrade but have been told by numerous ppl (including the tuner) that it will be fine
Very keen to see this result!
Standard cams?
The whole flex fuel thing is awsome. Just drive around and not worry about a thing. Does the Haltech setup come with a Ethanol % display?
yep standard cams... wanted more mid range than anything else really
the Haltech doesnt have a e85 guage as such but you can monitor the % if you hook it up to a laptop
cant wait :banana:
I feel ripped off reading this :closedeyes:
I thought this was the end result thread lol... Guess we wait 2 more weeks :D
I'm with a few others, not so sure the -9s will hold 28-30psi. They generally always fall over so very keen to see end result
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
