Hi guys
I have a 91 R32 GTR, has a fully rebuilt motor to all N1 specs. N1 Turbo's, N1 oil/water pump etc etc. Has 1500km on it. Also have a 3'' exhaust and HKS Pod filters. I'm getting it fitted and tuned with some parts soon. Feels like its runing stock boost at the moment. So not sure how much its making.
Apexi Power FC pro + Hand Controller
Apexi Boost control kit
Nismo fuel pump 276 lph
Nismo fuel pressure regulator
Sard 700cc injectors
I'm just wanting to know everyone opinions on what kind of power I will make at the wheels once I have this work done. Since I have the N1 turbos, I'll probably be getting it tuned at 15-17 psi. I Heard i'll make 250rwkw+ and then heard from other's I should crack 300rwkw.
Your thoughts???
https://www.sau.com.au/forums/topic/387994-r32-gtr-mods-how-much-power-output/
  • Replies 50
Posted Images
Around 265 depending on exhaust restrictions.
Only one way to tell for sure - tune the thing and come back with a result. Then put it in the RB26 dyno thread which is up the top of this section.
N1 is not all forged.
If it's been build to strictly N1 specs - it will still have ALL the problems that RB's have factory especially around oil control etc.
Basically you need boost either way - read the dyno thread.
Yea sorry, didnt mean all forged, just ment Pistons etc. Yea fairly sure its been built to proper N1 specs. Ohh, I really hope I dont get all those RB" problemsthen haha :(. Boost it is. Hopefully 18psi will be comfortable for it.
Edited by 91BNR32
I bought it, and the guy rebuilt it all to N1 Specs, inlcuding turbo's etc. I dont think he did the oil system which would of been smart, just has gthe N1 oil pump etc. so that's why I thought 18psi is probably enough for it. Has only 1500km since the rebuild. But you guys would know more than me.
Just wanted to see what kind of power it will make with those mods, and it looks like high 200's. maybe 300rwkw with 18-19psi.
Mine made 400rwhp at 18psi with R34 N1 turbos.
Same.
91BNR - you should have no problems getting 300kw, and you shouldn't need to add any other parts to get there. The only thing you could add is adjustable cam gears, to help low end response.
yea I thought about cam gears, not sure if really needed them though. How about the Stock R32 GTR AFM's. will they flow 300rwkw? I mean i don't wanan keep spending more money than I need too. Gotta draw the line somewhere lol. and 300rwkw would make me happy
Those turbos+ 700cc injectors and standard afms should net you 300 rwkw.. Standard afms start maxing out at around 310-320 mark
Make sure it's a safe tune, dont bash the limiter, service the engine properly and enjoy
Who's tuning it btw?
Stock injectors will be fine as well. They will run out 280-300rwkw as well. Spending $700 on injectors and not doing the AFM's is a waste IMO.
If you run out of injectors, just up the rail pressure a bit. I've managed 340rwkw out of stock injectors via a very tiny bump in the pressure. Wouldn't go any more than that but it can be done and reliable.
Thanks for the advise guys. From what people are saying, I might just leave the standard injectors and AFM's and get it tuned at 16-19psi. And just see what I get. The injectors have been Sonic cleaned, flowed & tested with new caps, so they would atleast be in good healthy condition. And the AFM's have been properly cleaned aswell. If I get close to 300rwkw with that I'll be happy. As I am on a budget, no point me spending another $1200 if my injectors and AFM's are holding up well at high 200's/300.
Power FC
Boost control kit
Nismo Fuel pump 276l
Tune 17-19psi
= See what I get for now :)
Would people agree that if I wanted to go furthur after that, it would be 700cc injectors, Z32 AFM's and Cam gears?
Cheers for all your input, helps me out alot.
Edited by 91BNR32
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
