Hopefully this has'nt been answered, but I am about to finish all my refit of my s1 rb25 and I need to confirm about the timing belt tensioner, the spring is meant to adjust the belt correct?, so i did this and it doesnt hardly even move the belts slack... Am i meant to wind up the spring before fitting it over the stud it sits on? I set my belt with an allen key, but im worried about tension. I set it last time too tight and it was making a whirring sound, I want some reassurance/help with this because i have a near 20k motor that I dont want to **** up. Thanks
The Nissan manual says to put the engine on TDC and loosen the nut on the tensioner. Do 2 full laps of the crank and stop back on TDC. Then tighten the nut on the tensioner (use an allen key to hold it in place). I've done it this way on 3-4 cars now, and it works a treat
None of that info helps if he hasn't got the tensioner spring doing its job.
Yes you have to preload the tensioner to get the spring working, otherwise it will just sit there as you found out.
Take care you don't get any windings gaught under the tensioner where it mounts to the block, that will cock it over and run the belt off.
Next as it's a Gates belt, my opinion is that the workshop manual info won't work, the belt gets too tight once things reach operating temp.
From experience Gates belts have to be setup looser than the factory belt, which is why no more Gates belts for me.
You need to be doing belts daily to have the "feel" for Gates belts.
I did mine by relaxing the tensioner and turning the harmonic balancer a few revolutions. The tensioner will than move into the correct spot and all you have to do is keep pressure on the belt and tighten the tensioner up. Hope that helps ( I was told this by 3 different mechanics so hopefully its right as i had over tensioned mine as well the first time ) Had no problems what so ever
jiffo's right, I know how to rotate to set and all but my spring itself isnt right, it holds all but zero tension on the belt. Its not damaged just not coiled up....
So when it used to whir with my first build, it was obviously too tight, so can it be all but whirring? I realise what a loose belt ends up doing, but what does a slightly too tight one do?
Thanks for the input though guys
Mate does it have the stud in the block that the spring rests on to put tension on the spring? If yes then your probably just not locating the straight part of the spring correctly. A belt thats too tight causes a few problems but most noticeable (what i see on engines that have been built by others that ran belt tight) is excessive wear on the 2 very front cam bearing tunnels, the one which holds the seals, its always on the inner side as the belt is trying to pull the cams towards each other. Belts also tend to go shiny when too tight. I usually run about 4 deg play. ie: wind the engine over by hand (breaker bar) until you pass a compression stroke (doesnt matter which cylinder) but you'll feel belt looses drag. rock the crank back n forward n you should have about 4 deg play...Hope that doesnt confuse you too much but its not that difficult. Just take your time ;-)
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
