Hey guys! This is my very first post on this forum, and I need your help!
I'm buying a car on Monday, I drove it today and it feels like its misfiring when boost kicks in...4-4500 rpm..it's only sometimes it does it as I went back to look at the car a second time and it didn't do it. So I was thinking a Chang of leads/spark plus/ spit fire coil packs are the problem??? My friend told me this is a normal problem most r33s have??
If someone could let me know ASAP before I buy the car on Monday that would be great!!
Thanks guys
https://www.sau.com.au/forums/topic/388264-car-misfiring-when-hitting-boost/
You have made some very astute observations & I am thankful for the effort you have put into your writing. It is clear that you know what you are talking about. I am looking forward to reading more.
Borrow money now borrow money online, borrow cash online borrow cash now.
viagra meilleur prix viagra viagra pour homme
Why would you buy a car that is playing up?
Because you predict the fix will be easy?
My Stag had a misfire when I bought it. It caused a few minor headaches at first, but nothing major. I still haven't solved it, but I'm fairly sure it's the coilpacks.
exactly right. im predicting its hairline fractures in the coil packs, as ive read on here its a easy fix but id like to get a set of splitfire coils anyway. the car just had a service 3500 klms ago and hes got recipets that timing belt was changed and the other regular service duties were carried out....the car is great its just this little misfire problem. i took it for a test drive and told him when i got back. he said he knows it happens but only sometimes which is true as i took it for a drive again and it didnt do it...therefore he lowered the price, to compensate me for fixing the problem...
i suggest u can be a bit of a hard ass to cover yourself.
IF i was buying it i would ask the buyer to solve the problem, if its plugs and simple things its weird that the buyer would not fix this himself to sell, thats just f**king lazy, i would suggest its something more, not major just something he cant be assed spending money on to sell.
if its coilpacks then make him replace them. if it fixes it then u pay for the parts but if it dosnt fix it then u dont want to buy.
He has no clue of how to install anything , he gets he's local mechanic to do all the services for him, he just told me that it happens more often in the colder mornings, and he's never thrashed it to le it happen..
Thanks guys
Matt,
I bought my R33 with a similar problem. I did, however, have the car inspected before I had bought the car. He was 90% certain it was the coilpacks (which as you've found out, it a common problem).
The tacho was also faulty (again, a common problem)
So knowing that those things are wrong, and also knowing fixing both are very straight forward diy's, I got quotes from professionals to fix both, presented that to the seller and shook the f*ck out of the selling price ;)
Naturally any quotes from mechanics are going to be sky high when they quote factory parts! Haha
He accepts (as like your seller, he knew f*ck all about cars) because he thinks his car is terminally ill, and you make a killing - with extra money now ready for mods! Good luck.
Matt,
EXACTLY my point ^^
i bought some silicone, the industrial grade 401 selley's stuff as i read on the forum that fixes it. is it worth taking and trying there before i buy it?
Well I have almost the exact same problems and have just ordered a set of YJs so I'll let you know how they go. Assuming I get them in the next day or two, they will be in by the weekend.
Just a quick reference, splitfire is the only correct fitting replacement, all the others only use 1 bolt and sit slightly angled as the bolt holes are wrong.
Have you considered that perhaps the ones which "only use 1 bolt and sit slightly angled" weren't the correct ones for an RB?
All 4 sets I bought were for an rb25neo, and 3 of them gave me my money back because of poor fitment quality. The 4th was splitfire.
Well, I'll let you know how the YJs go for me.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
