does anyone have a guide on the correct procedure to remove a series 2 rb25det engine from a r33 in the correct manner. i can pull an engine no problem but i just want make sure i dont run into any snags along the way. as i only have 2 days to do it.
thanks
https://www.sau.com.au/forums/topic/388552-gtst-engine-removal/
I don't imagine it would be too difficult mate
Remove gearbox, disconnect exhaust, plumbing, wiring loom, fuel lines, coolant hoses and radiator for more room
Remove the nuts from the engine mount studs and pull it out :)...
I'm sure there's a couple of other little things but that's the most of it
Drain all the fluids first too ;) except clutch and brake of course
Do a GTR, now that's a pain in the ar$e lol
ok im looking for help not smart arse comments, yes i could take it to the shop im not retarded. the idea is A. so i save some money! and B. i can do with the experience of learning as most of you guys complain " oh the new guys to imports dont even know a there way around a car they just take it to a mechanic and say make my car fast" well herei am trying to learn how to do it myself. right o
that last comment wasnt directed to u mate, thanks for the help
maybe you can also help yourself though by doing some research first though...
http://www.skylinesaustralia.com/forums/topic/41121-removing-a-gtr-enginegearbox-plus-more/page__p__843424__hl__engine__fromsearch__1#entry843424
yep its for a gtr but it should still be fairly similar
pretty straight forward, unplug everything wiring loom related, remove intake piping/intercooler/vac lines/radiator/clutchfan or thermos, unbolt and tie out of the way AC compressor and power steering pump, remove gearbox bolts (ones up the top are dream boats), attach engine crane, undo engine mounts from cross member, check you have everything free/clear/unplugged and remove it keep in mind the engine must come forward to get the input shaft from the gearbox out of the clutch.
http://www.skylinesa...__1#entry843424
i have been searching all day all i can find is gtr manuals. thats why i posted here,
I have just rebuilt my engine and i couldnt find a written procedurethis is what i did.
Disconnect battery Remove Exhaust dump pipe to tail pipe drop engine coolant and remove radiator
Remove plastic around shifter and remove shifter cover & remove g/stick
Disconect neutual and reverse switch connections also remove clutch slave cylinder and tape it togeather so it doesnt leak zip tie it out of the way
Undo tailshaft but dont remove Jack and support rear of engine so it doesnt hit the steering rack get it a low as you can as i had to use very long extension bars to get to the bellhousing bolts remove transmission with tailshaft connected so not to loose oil. Also keep engine supported.
Disconnect Engine wiring loom oil switch steering switch air cond wire. Undo heater hoses turbo to air filter brake booster vac hoses fuel lines disconnect pwr steering res and drain
Unbolt and remove pwr steering pump and braket. Also unbolt air cond pump and bracke zip tie out of the way.
Undo engine mount nuts and remove engine
refit engine in revese order
I hope i havnt forgotten anything
ote name='riley' timestamp='1326791310' post='6192287']
thanks
Forgot on my last post
ALSO TAKE A COUPLE OF ENGINE BAY PHOTOS BEFORE YOU START THAT WAY YOU HAVE A REFERENCE FOR INSTALLING THE ENGINE AGAIN
thanks
i find pulling the box out with the motor is much faster. unless you have a hoist with rattle gun and massive extensions to undo gearbox bolts.
mines a rb2530 with custom mounts and getting the the gearbox bolts are some what impossible.
Yep I pulled mine out with the box on.
The ones i hae done we pulled them with the box attatched. Much faster :) Just dont forget the clutch line :)
But as suggested its the same as every other engine. Unplug plugs, un-do hoses.
If its a stock turbo, then removing the turbo and dump pipe in one piece is highly recommended :) SO much easier than undoing and doing up those assf**k dump pipe bolts lol. It can be done.
as said leave the gearbox attached. leave p/s, air con and clutch slave all attached to their lines and unbolt them from motor/box so you dont have to deal with any of the fluids. make sure you pull it out somewhere with plenty of height clearance as you'll need to get a fair bit of angle to get the box out aswell.
best bet for getting it done quickly would be to find someone on here local to you and pay them with beer to give you some guidanc. once you know what your doing you can go from complete running car to motor on the ground with box off in around 2 hours working at a steady pace, rushing just leads to losing skin....
Edited by JonnoHR31
i loved my SR20 use to have the motor & box out within 1 1/2 hours. when i changed the clutch i use to rip the motor with box out together done in like 5 hours and driving LOL
the RB does take longer but once you do it a couple of times it gets faster
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
