I recently bent the valves on my rb25de. After getting quotes seems its gonna cost more to get it rebuilt then just putting on a second hand head. my problem is i am having trouble finding many de heads. however there are loads of det heads around. so what work is needed to make the det head run like a de? on my p plates so just turboing it isn't an option. also is a de neo head basically the same as a normal de head or what work would that need?
what is cheapest option?
thanks heaps in advance
(i have searched but couldn't find any info)
https://www.sau.com.au/forums/topic/388699-25det-head-on-de/
not sure if the head of the DET head runs lower compression (know it runs lower compression pistons). if it does then you will be down on power. plus you will need to use the NA cams.
another option would be to just buy a complete motor and bolt that in.
Buy new RB25DE for around $1K, maybe not even that and then have it fitted into the engine bay. Become epic winrar. Also less screwing around involved.
A head change is much easier IMO to perform then a full engine swap... Had to do both a few times...
yea both options are seeming to have their ups and downs.. the head replacement is by far the cheapest but im worried once head is taken off will see damage to pistons.
im pretty sure also they use the same cams (de & det). from what i found the r33 rb25 is the only rb thats head doesnt change from turbo to non-turbo. but im still not 100% sure weather the det head is a viable replacement for my de head? im sure it will work. because i havent found anyone who has said no yet.
the cams between the two heads wouldnt be different enough to make a difference to the ecu . . .just buy a complete RB25DE from SSS for around $750 plus freight and you get a warranty and no mashed pistons!by the time you have messed around swapping heads ($ gaskets) this is the easiest/cheapest/quickest solution for you
well $750 isnt bad. where or what is sss??
A head only swap isn't cheap.
Buy head, 400-500.
Have head serviced and crack and presure tested 300-500
Gaskets 60-300 dependin if you buy just HG or the VRs kit.
So 760 at the cheapest in parts, plus you still need to do it.
Just depends on if you can actually do the spanner spinning yourself.
I've just been sitting here at work contemplating about head swaps, if a turbo bottem end was purchased could one of my NA heads bolt straight up to it.
If so, would head porting and cams (assumeing the same duration and lift still works with a turbo effectivly)be used on an NA until the pull me over plates come off?
or bolt a turbo to your NA setup with some medium boost (12-14psi) and youre laughing......still its pretty expensive and if the engine is worn you going to have to re-build it anyway.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
