  • Replies 131
Will be running a 6boost twin scroll manifold.. I'm not to fussed about the exhaust housing size, with the head mods and dual wastegates ect. I think it'll come on boost the same as my -5's...
Hey guys, Sorry I said I'd update this on the weekend, but I guess I was just lazy/to busy trying to put this engine back together...
Okay, so I have finally picked up the engine from Tony and it looks great!! :wub:
The only issue is that the drain at the back of the head isn't one of those alloy block ones, it's just a areo fitting bent into a 90* bend. It's probably a 5" diameter bend so it's going to need to be changed for a smaller one so it will clear the firewall..
Engine
Sump
Exhaust Port
Intake Port
I took the engine over to BoostWorx thisarvo to get put back into the car.. On my way there I picked up a new Xtreme Carbon Twin Plate Clutch with Cromoly Flywheel so now it will be able to handle the 450awkw that she'll be packing haha :3some:
Cant wait to have her back!!
Hey guys, picked up the turbo and manifold today do I'll post up pics tonight, looks sexual haha
Everything is coming together..
I need a bigger fire place so all the cash I'm burning on this will fit hahaha
Hey guys, sorry I haven't updated in a while, I've been busy moving house and trying to organize this thing at the same time haha..
Well, I went over to BoostWorx yesturday to have a look and I must say what an excellent job they have done, the amount of work they have done in the last two weeks is amazing!!
Engine is in, turbo is on, clutch and all fluids are done!!
So while I was there, it was time for the first start up.. Always an exciting time!!
The engine turned over, and over, and over but didn't fire... Just a few splutters from the exhaust!
Turned out the the insert to be pressed into the front of the exhaust cam to turn the cam angle sensor wasn't installed from CamTech.. This ment the senors wasn't turning and the timing wasn't ever going to work..
I got straight onto Tony to see what we could do. He called CamTech and sorted out a R32 insert to go in and a R32 cam angle sensor, should be here today and 11am. Hopefully, the car is started and a basic tune done by this arfternoon :) WIN!!
I'll post photos of the engine bay and progress tonight..
Wtf was that... Damn iPhone.
Can't wait to hear your result Brad
Yeah cheers mate, can't wait to get her back on the road, hoping for 450awkw on E85.. Should get there haha
Soooo, quick update!!!
Engine runs!! However, there is an oil leek at the front crank seal and also a little one at the rear main seal.. Engine is literally brand new so must have been a kink in the gasket when it was put together or something..
Shaun is fixing the leak this week and is going to bed the engine in on the dyno next week.. Can't wait to see some results
  • 3 weeks later...
Hey guys, so today the engine ran properly for the first time..
It ran for 40kms doing some basic bed in things and then got its run in tune;
279kw @ 9psi 8000rpm
Boost pulls as early as 3000 rpm!!
I'm so happy with the figure, it's more responsive then my -5's on my standard motor... With E85 and 28psi I think an easy 500awkw is achievable..
Who ever said you can't have power and response??
Cheers
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
