Anyone had much experiance with Skyline engine conversions? Plans are to take it down to the work shop But i would like to learn a few things myself.
Not so much the wiring and other bits mainly the grunt work, Old motor out and new one bolted in.
Let me know, Cash and beer you way ofcourse :)
p.s Rb26 into R33 GTS4.
https://www.sau.com.au/forums/topic/389007-engine-conversion/
Rb26dett into the R33 gts4,
Car atm is in working condition, So engine will need to be taken out, And the new one droped in at bolted in.
Also have a 5 stud conversion needed to go on,
Have R33 GTR front hubs, 32GTR Front brakes and braided brake lines
Rear 33 GTSt hubs and brakes with braded lines.
Also have a loom but no clue on how to set that up or any other wiring.
Do you have much expericane with this type of thing? Shoot me a pm if you want.
Cheers
I may be able help you. I removed, re-built and installed an RB25DET into my HR31 3 years ago and am currently building an RB30/25 to go in. Haven't had any experience with an RB26 but they are pretty well all the same and I do have the full Nissan RB20/25/26 engine workshop manual, so that's all you need.
I also fitted different suspension, brakes and a 5 stud conversion on the HR using Commodore parts and stud pattern.
I live at Pymble just down the road from you. let me know if you would like me to drop over and have a chat.
Hey guys, I'm new to the forum and I'm also a new skyline owner. I found this forum and have lurked it for about a week now and all you guys seem legit with advice and knowledge. I have a 93 R32 gtst rb20det. I am very keen to get it restored into a reasonabIe condition. I am a P plated driver and obviously cant drive a turbo vehicle. I'm just after some advice here because I didnt want to start a whole new thread. I have an rb25de neo sitting at home, I'm unsure if the engine is rwd or awd and it came with an auto gearbox. I'm wondering what kind of manual gearbox I will need. Will I need an rb25 neo gearbox? or can I use an rb25 gearbox? Is there a difference between them? Could I use an rb25 turbo gearbox? What kind of gearbox mounts will I need? Does anyone know where I can have the engine swap done with quality?
I do apologize for the novel of questions I just wrote but I really want the right advice from the right people and people who have knowledge in engine swaps as I'm no mechanic. Any feedback would be greatly appreciated.
Can i buy the 25de intake + airbox?
hahn, you can use the stock 20det gearbox no worries, if you go turbo an 180rwkw plus id think about upgrading. basically any Rb series gearbox will fit. you will need custom mounts for 25 gearboxes.
but as i said jsut use the 20det box it will be fine.
The only problem with this is that putting a 25DE Neo into your 32 still counts as an engine mod (and is therefore not legal/roadworthy), even though you're decreasing the power. Sucks, I know.
(Just playing devil's advocate here, I appreciate that you're trying to do a good thing, eg. no turbo)
Putting a non turbo motor into the car doesn't, in the eyes of the law, change it from being a turbo car. You will need to do the conversion then have the car complied as a rb25 non turbo.
Sydking, if you need a hand(seems like alot of people offering their help), ill help out. I ripped out my motor and what not also put a few cars together(non RB's but the concept is the same). Also with the loom, if I recall correctly after stripping my car, you shouldn't have to rewire things, just replace the loom with the appropriate new loom. It controls everything in the engine bay. All other electricals(headlights, ac etc) are independant I believe but you will probably need to fiddle around with the fuse and relax box. The mechanical stuff is much easier than the electrical.
Is the 26 a direct drop in for your 25 awd crossmember? Are you doing to be taking your box and engine out as one piece and then putting them back in as one piece? Ill tell you its a pain in the f**kING ARSE to get the gearbox bolted back to the engine but its an another pain in the arse dismantling your car to be able to slide the engine and box out as one piece.
ive got the 26 loom to go in, Power FC most likely for the ECU, Yes the 26 is a straight drop in ( there will always be a few hicups) , Gearbox is not getting touched untill its broken, Jim berry clutch will be installed though.
Dont think there would be any reason for me to get rid of the air box, though if for some odd reason it dosent fit, you can buy it
Its all good now, I deceided to keep my skyline as is and keep it for a track car until I get my blacks, I didnt really want to castrate my ride. As for the time being I'm going to get all the bits n pieces I need to get some more reasonable power.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
