Hey guys..
havent had this car for long and only noticed that, once warmed up, the needle is 'sitting' on 2/3 up towards H!
I must of did a 2 hr drive back home when i first realised and seemed fine.. continues to be fine now
the car is completely standard bar frount mount and exhaust
I've already drained old coolant and refilled with new, checked and replaced radiator cap and thermostat.
im not sure what else i may be able to do?
been searching around i cant seem to find anything about it?
https://www.sau.com.au/forums/topic/389071-overheating/
If its overheating while driving ie: sitting on the highway at 100 --- I would be checking the radiator for blockages.
best way to do this (as far as i know) is to remove the radiator, boil the kettle, rad cap on , lay it down flat and poor the boiling water into it.
When its full, place your hand on the fins and move it all around feeling for areas that are cold.
When i did this with mine it was really easy to pick up,, i had a large area that was blocked.
If its overheating when sitting in traffic jams, then look at your viscous fan clutch.
google has plenty of advice about how it should operate and how to test it.
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6201290
So your saying that it gave you the same reading after you changed the thermostat, did a flush, new coolant and thermostat?
If it did, then as mentioned it can only be one of two things, dodgy temp sensor or blocked radiator.
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6201426
Yes use a consult cable ASAP. Assuming the stock gauge is correct, any movement upwards means your temp must be at least 110C and you're about to cook your motor. I've had my temp (reported by consult) as high as 104C and the gauge still said halfway.
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6205449
After it's been warmed up, whether i'd be sitting in traffic or on highways at 110, the gauge would read the same or close enough.
After all the above where changed and replaced it remains the same. It did however go very close to the line below H after a long drive from City to Penrith and back last night but dropped shortly after, while still travelling at the same speed :/ ?
I havent had the chance yet to try the temp sensor and radiator but will do this weekend if possible. I dont have a consult cable so i might just take it down to the mechanic to check this asap.
Cheers for the info guys i'll provide an update
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6205991
so i haven't yet been able to take it to the workshop to get it checked out as yet due to work and other commitments...
i did just come back from the garage after having another quick look at the car again.. had a quick look at the radiator and the core is only 15mm give or take!!!!??
i dont know how i missed it before but just checked the part number on the top tank... PAT-APP-48-86457.. quick research reveals possible DE radiator or some sort :/
does anyone have the part number of their OEM radiator to confirm?
I think a new radiator is definitely a must!
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6214553
Clogged radiator, or fins on the water pump after that, more than likely a clogged radiator
As mentioned could be a faulty temp sender too, you never know....
Edited by GTRPSI
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6214685
I went ahead and just got a new all alloy radiator and silicone hoses. Got everything fitted fine. The workshop took it for a spin to get it up to temp and apparently thermostat wasnt opening!
Top hose was boiling and bottom hose was very cool.
After changing almost everything in the whole cooling system it ended up being a dodgy waterpump :(
Well at least the problem is now gone!
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6234006
did you do a timing belt kit when you did the water pump?
At least you know now that you won' thave any overheating problems.
FYI - 3/4 on the temp gauge is about 105 degrees according to my ecudatascan device which connects to the consult port.
From there it gets to 115 really quickly.
May have cost you a bit of money but at least you are not up for a broken motor.
here are a list of things ot try in order of cost (cheapest to most expensive) for others who may eventually come here and search for "overheating" "radiator" etc
Radiator cap - New from nissan - part number available in forums
New coolant (personaly I'd dump coolant, hose out radiator, fill with demineralised water and bleed off and drive for 30-40 minutes and repeat 3 times - letting it cool in between obviously)
new thermostat - New from Nissan - part number available in forums
now starts to get expensive....
New radiator or get your one cleaned by a radiator shop (keep in mind that if you get a new Thicker radiator, you may have issues with the factory Viscous clutch fan touching or the shroud not fitting - Shroud is VERY important to have on the radiator for the fan to work to full effect.)
New viscous clutch for the fan
New Water pump (might as well do the timing belt and make it a proper 100K service)
My suggestion is to NOT use a radiator flush kit that you can buy from supercheap etc - By doing so, mine got blocked more
I'd also replace the top and bottom radiator hose if replacing the radiator.
https://www.sau.com.au/forums/topic/389071-overheating/#findComment-6234094
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
