  • Replies 57
Yeah seems a bit of a problem with them.
To the guys that have had their M35 turbo blow, are the turbos dying due to bearing failure from oil supy issues or the ceramic turbine wheel coming apart then leading onto shaft/bearing failure?
Oil supply and poor servicing IMO. Coupled with the senario of it being a warranty item in Japan. Remember they run a lot more psi standard than the c34's. After they are rebuilt I haven't heard if any other turbo issues
Edited by Jetwreck
I don't think mine was either an oil supply nor servicing issue. My exhaust wheel just decided to part ways with the rest of the unit and was found in the cat, but yes it seems to be a recurring issue with M35's.
It's also a good excuse to start modifying (was the first mod on my old Stag lol). I'd be interested to see how long the stock turbo would last with an aftermarket dump and exhaust.
Exhaust restriction is one of the main culprits IMO
My thoughts are on the extra boost the M35 runs and shitty factory dump pipe causing excess heat and shaft speed on the turbine wheel.
I currently have an a/market dump and soon to add a front pipe with 200cpsi cat and keep the stock cat back, unless I come across a factory option Nismo system. Will be interesting how long my turbo will last. I oil change every 5000km and rarely give it any stick. Having said that, last week I relived my younger years by going up against a VE SS manual and VZ SS auto. Left the VZ a good 3 cars behind and the VE sat side by side. Boy did he look shocked ?. I didn't stall it up for either.
Edited by slippylotion
Yeah well not sure on the exact cause of why mine failed but the bearings were rooted and I think a bit of damage to the impeller.
So it's all getting replaced.
Anyway hopefully it will be back in car soon! What sort of a difference does the hiflow make? I've searched a bit for info but am yet to find much. Keeping in mind that everything else just about on the car is stock.
Will probably be looking at Jetwreck's banjo bolt mod when it's done to hopefully eliminate a but of potential for future issues.
Cheers
Nick
We have been over this before, if the oil supply stops, the rear bearing will fail fairly quickly. Definitely check the banjo if you hear the common jet turbine noise and get ready for a rebuild.
A highflow will do bugger all for the power output without tuning the ecu. All you will gain is lag unfortunately.
HKS make a filter- I have one in the kit that I did. Just goes in line with the braided lines. It is able to be taken apart and cleaned. The Japanese instructions that came with it said you clean every 5000kms. Don't know if worth it, but just putting it out there.
  • 3 weeks later...
I'm about ready for my car back... Going on a month at a mechanic recommended by my warranty provider. Getting part of costs covered.
I think the turbo was or is getting rebuilt by gcg.
Apparently there is only one mechanic at this workshop that knows how to put a turbo in and he's on holidays, only took him 8 hours because every bolt under there was stripped already... And quoted me on 8 hours getting it back in, yeah right.
Anyway this update should have come 3 weeks ago... But alas here it is, no need to say I'm a bit over it!
any reason for this comment? looking at getting an M35 through them...
Lets just say that some of their cars "coincidentally" have been known to have similar mileages; around the 50-65 000km area.:whistling:
That's not to say you won't get a good one; I bought mine from them and it had 39 000km (which I do believe to be fairly genuine). It's been basically perfect. :thumbsup:
Just make sure you see the original Japanese auction sheets PRIOR to laying any cash on the line. As with any sale, if it doesn't smell right; walk away.
Alex was great to deal with, but Dmitriy; not so much. Made a lot of promises, (all promises had been made via email) and then promptly forgot about them when it was time to deliver, Alex sorted most of it out.
I believe Dmitriy has since moved on, and is still on form...
All car yards will have bad stories; some due to genuine issues, some due to unrealistic expectations. There are a lot of good stories too, but people make the most noise when they feel they have been wronged.
Build a relationship with the dealer and I believe they will take care of you.
If you don't like the way you are treated in the beginning; I don't believe things will improve down the track, if you have an issue.
Edited by Daleo
yeah no worries, ive been speaking to a bloke named cody, really nice dude... just wanted to check in about that comment, this one has 43xxx on it, will ask to see the original JP auction paperwork.
Thanks for your help dale
Thread Jack.
Remember, cars can get a "hair cut" before they even make it to auction. So look for the tell tail signs of higher Kms- wear on gear sticks, steering wheels, carpets, rubber bushes under the car, and generally scruffier condition. Rust / corrosion (more than normal) on bolts and things under the car means a car thats come from a snow area with salted roads.
The Japanese de reg paper is what you want to see. That has the last 3 inspection dates and km recordings. Just make sure you see the original certificate and not a photo copy of the original.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
