R33 S1 RB25 with nice deep gouge marks in 2 bores
mods: genuine T6725G 8cm, standard intake manifold, HKS cams/cam gears, NO VCT, RB20 loom and ECU
fuel: BP98
power: 311kw on 19psi
oil: penrite 15w40
useage: drifting
lifespan: have only done 1 event in it so far but seems strong, no blow by or anything
failure: none yet
E16C0E13-7A45-4DF1-81D6-4948F531E79F-252
Hey guys, can I join?
mods: 3" exhaust, greddy 600*300*76 intercooler, nismo fuel pump, nismo 740cc injectors, Hypergear ATR43 G3 turbo, low mount, stock manifold
fuel: e85 Caltex EFlex
power: 304 @ 17psi (clutch slipping so can't go further)
oil: Castrol Edge 10w60
useage: Daily driver - to and from work - occasional mountains flogging or track day
lifespan: Owned for 3 years still going
failure: None - touch wood
comments: So much fun!
Hi Tranman , I'd like to see your intake from the Z32 to the GTX3076R if possible because many claim its difficult to do .
Do we know for sure if the std GTS25T airbox can't support 300 RWKW , I still have mine and it has a cleanable Piper Cross element in it . I'd also like to see the box mods as I like stealth and I'm using the same IC as yours . The airbox in R33 GTRs must be significantly better if it supports more than 290-300 RWKW .
Good effort , cheers A .
Pictures (below) of what the workshop (Chasers Motorworks) did to open it up the stock airbox. They also fabricated the intake pipe to the turbo using a silicon hose joiner from the z32 to the 3" metal intake pipe before joining to the turbo via 3" to 4" silicon hose fitting. I was advised it was a bitch to do by the workshop.
The stock airbox was holding me back on my car hence needing to drill out holes. Not saying it will/may hold others back if they have better flowing setups etc.
Was tough getting a pic to show you the pipe from the z32 at this time, but you may be able to just make out how it reaches the turbo.
I looked up pics of the R33 GTRs airbox and it seems to lay on its side so there is a greater volume of air either side of the element .
Has anyone tried to use the 33 GTRs box in a 25T ? Probably a bit of stuffing around making a Y pipe but if you're doing something for a bigger turbo inlet ?
A .
Edited by discopotato03
i wouldn't worry about water... I ran my car like that for 5 years with no issues.
(not the hole cut in the stock airbox, but a pod in a custom box with a CAI from the front bar
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
