This here is my unopened rb25. Has a surge tank,
044 pump, 750bosch injectors, e85 fuel and an apexi
Power fc. Turbo is a hks 3037 .63 rear housing with a
Garrett front cover. Tuned by smmotorsports making
344.1rwkw on only 15.8 psi. Since October last year
I've done 5 drift events, Phillip island sprints and
Winton Vic time attack over Easter. Engine still has
no signs Of wear.
Hmmmm interesting, my car has tested the limits of that turbo in every way and with a 0.82 rear on the same turbo with every supporting mod possible the best we ran was a 320-330kw...... 344 required 20psi bleeding to 18 and that is with the bigger rear housing!
yeah, I think we can conclude it's a happy dyno, however it's definatley a 300+ car and would be an assload of fun
Yep not doubting that part! It is an awesome combo and tried and tested many times! Good result and welcome to the club haha
  • Like 1
Good to have people around who are willing to try and test combos so you know what works :D Your car has become a bit of a benchmark for the GT3076R's ability, I reckon!
Well we have found the limit with this combo and will be looking to improve where possible, the 3076 and RB25 were made for each other :yes:
:ph34r: swap it for Hypergears VNT and get 400kw.. do it!! :yes:
Edited by AngryRBGTX
Not convinced on that as yet! Good result for sure but there are other ways to make power on mid frame turbos! You should know, you are about to try ;)
srsly?
it's written on the chart :P
:laugh:
I know i'm probably going to be shot down in a ball of flames for this.... but is there any real point in shooting for 400?
surely it's just useless power unless you have a very very good and expensive setup
@ 320+ rwkw in a 1.4 tonne chassis I needed to run NT05's just to have a hope of traction, and on your average tyres it was already game over.
seems to me like it's just inviting the motor to pop for power that you will never use beyond a dick measuring contest
No need for flames, it is a pretty decent comment and something i have also said in regards to my car... My tuner was saying i should go to the 35r frame turbos but i said i was overall happy with the performance....
Overall i think mine needs a little extra spool and maybe more in the top end for drag and long open circuits.... For street and hill climbs i would be running gate pressure anyway so it gives you all options.
My car is only running RSR 265's but once warm i can start to get them to grip up, of course i cant launch the car on them but that is where MT tyres will come into play!
As an all round car to do all events i dont see boost settings allowing 330kw, 360kw and 390kw to be a problem as you cover all bases and still have a damn fast car!
Of course bragging rights too :P You know, coz racecar!
I would love to have more because i can! But the old 3037 has nothing more to give! I will continue to seach for a better way haha
Finally some results. Slap us with a teaser.
Sent from my HTC One XL using Tapatalk 2
Haha yeah some results for you finally! And it went over 500rwhp as planned ;)
Well the meth injection is finally installed after months and months.
Was hoping to join the club but might fall a little short of 300 :(
Looks like the old 2835 pro s is maxing out and we have had to tune to fight off knock rather than outright power.
Back up to JEZ tonight to finish the tune and try a couple of things (cam gear adjustment, adjust afr etc)
You never know, I may get there buy I am a little doubtful.
Ah damn! Well i hope it goes well! Shame i hadnt picked mine up from its tune today or i would have popped in and said G'day!
I stay in this club with 390kw :woot:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
