Hi all,
Was hoping for some advice, just lost my ceramic turbine out the exhaust of my stock Series 2 R33 with the RB25DET and who should I get it repaired by, or should I just replace it?
Only got a stock motor with high kays on it... (270k), standard in guard I/C, standard ECU and about 10psi.
Suppose, I must have either hit more boost than that a few times for it to let go, that or I had a bearing let go.
Either way the turbine wheel has gone now and the car lost a lot of power (no really! lol) and the rear seal was weeping a little oil so I had a smoke screen following me at any rev above idle.
Got the car home, without upsetting too many people but I need my daily driver back!
Not interested in rebuilding the motor on this car or making it a high power, just need it back without too many hassles now or in the future. Really want bolt on and am happy to do a bit of work to get it done.
Who can overhaul?
Can I send it somewhere and get a standard overhauled turbo sent to me?
Can I buy a new spool assembly and bolt my bits on them?
What is the most cost effective?
Where do I buy?
Probably don't want to spend heaps but I don't want to buy cheap shit either, will possibly park the car or move it on soon.
Any ideas, who can help me please? Need the car back on the road asap.
I am in Geelong, Victoria not that this will make much difference!
Thanks in advance for any advice.
Stephen
Hypergear rebuilds them for about 8-900..will be better than it was, have steel wheels probably make a little more power too
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/
or just chase up a S/H unit on the classifieds..for 2-300$
Thanks Artz... very much appreciated. Lots to read on that link. lol
highflow turbos are only as good as the person doing the job. you cant say a highflow will kill your motor with supporting mods.
had one on a SR20 for 3 years seeing 18psi almost daily
with 270k on it, i would source another stock one and fit that. a high flow will kill your motor fast
He is saying that with more boost from a high flow it will kill a high km motor easily... not that the high flows are dodgy....
As for replacing the turbo.. good option with piece of mind is as mentioned get Hypergear to rebuild it, alternatively you can look in the for sale section here for people wrecking or parting out skylines... you can pick up a good condition stock turbo for about 200-300. the only thing is how long will it last again as they are getting quite old now.
think I will chance it and go stock.. if I can find one cheap enough.
wish the car was newish like 12 years ago when I bought it.
nothing like the choices to modify back then, unless you spent up big.
thanks everyone...
I don't know how much you can trust another second hand turbo. In all honestly most cars will have in excess of 150000km, hell even 200000km on them, so you will be buying a turbo just as old as the one you had let go...
Very true, however I think I know why this one let go... so I don't plan on letting that happen again.
Besides, don't go looking for R32 turbos. Try to find as late an R33 one as you can, or an R34 one if possible. Newer, less miles. Also less stress in your application (ie they can be boosted higher before failing when used on an R32, so at standardish boost should last well).
The best option would still be high flowing the stock turbo if you are keeping the car. as most of 2nd hand turbos are at their last legs either way. We replace not just larger steel wheels, but the complete CHRA, its more of getting a brand new turbo back in stock housings.
You do not need to replace the turbo again on engine change or rebuild, it can produce lot more power with better relaibility then stock turbo once upgrades are installed.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
