Hey everyone iv tried searching google and all that but I keep getting mixed answers. Now I'm putting a sr in my BMW and I have a sr box and a rb20 box either one will work I just want to know what one is better I don't want stupid answers only people that have used both. The sr box is out of a 180 type x and the 20 box is out of my old 32. The sr will be running a td06h-20g so I'm hoping around 260kw which the 20 box handled before. Anyone thats thinking buy a rb25 box I know they are better but a pain to fit up to a sr. Any info would be gold
RB20 and RB25 gearboxes bolt to the backs of RBs. So I would expect you would have the same issues using an RB20 box on an SR as you would an RB25 box on an SR.
The SR20 and RB20 internals are very similar though, with the same PPG and OS Giken part numbers anyway. So general health and age would be the determining factor one would think.
I would be sticking with the SR20 gearbox behind an SR20. Just be sensible with the sprung centre clutch and use good quality Castrol fluid and would be ok provided the car isnt being clutch kicked like a wet, stray dog
Yeah that's what I would do. I just don't want to put a weaker box on when I have both available I already need a custom shaft so I don't care about that. Also the shifter is in different locations the 20 box seems to line up near perfect. I'm not to worried about gearing as the diff in using (m3 LSD) is already in the 3.8 regon I think so that would decide most of how the car reacts.
They are for most part the same box, no real difference, just made for a different car. So go with the SR20 for ease of use. As for RB25 gearbox, you can buy SR20 adaptor plates so no cut and shut necessary. Running 260rwkw that's the path I'd heel heading down, personally.
I don't think it really matters which box you use. My experience has been that Nissan makes near indestructible gearboxes. (Although I have heard of 1 person who managed to lunch 3 RB boxes in a matter of months - probably using a VHD multi-plate clutch, and sidestepping the clutch at 7000 rpm.)
Since you are using a SR engine, it makes good sense to use a SR gearbox, IMHO.
another thing i've been told is that the SR has longer raitos. may want to scope that out for yourself though.
RB tops at around 200, SR at 240ish. (Same diff ) but again, double check that...
I can tell you now my 20 box seen more the 200 got 215 (nismo 260 cluster) before I slowed down on a private road of course diff is the main controll of top speed so the m3 diff would benefit from a shorter ratio box
Yuh, not even close to correct.  The RB20 will see over 180 km/h in 4th easily, run to much much more than 200 in 5th.  The main differences in ratios between SR cars and RB cars is that the RB diffs are shorter than 4:1 and the SR diffs are taller than 3.7:1.  The SR gearbox ratios are therefore better suited to the longer diff gears.
Bsa.  Just use the SR gearbox.  It is better suited to your engine and your diff ratio.
Edited by GTSBoy
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
