  • Replies 54
from what i know, you can get as many defect stickers as you wish, just have to do the same usual thing every time.
WTF did you get a red sticker for??? my mate got a couple because his car was barely able to drive over a cigaret packet. haha
https://www.sau.com.au/forums/topic/390285-3-red-stickers/#findComment-6224720
Both times been driving under speed limit in lots of traffic and both cops asked for engineer papers once I said I don't have any they said well you better ring a tow truck had nothing to do with how I talked or what I was doing if it had something to do with me I would of done opposite the 2nd time
https://www.sau.com.au/forums/topic/390285-3-red-stickers/#findComment-6225062
Maybe... Just maybe it was your lack of punctuation...
https://www.sau.com.au/forums/topic/390285-3-red-stickers/#findComment-6226960
Yeh stop talking shit and get back on topic if you don't have anything usefull to say don't say it people like that ruin forums like these
Everything has already been said to you! There is no more "on-topic" to discuss...
https://www.sau.com.au/forums/topic/390285-3-red-stickers/#findComment-6228393
You can be red stickered for bald tyres so don't run your mouth. ;)
This ^^^
It's pretty much up to the officers discretion what sticker you get.
Be nice, and sometimes they even say "Have a good night, just get those things we spoke about fixed"
https://www.sau.com.au/forums/topic/390285-3-red-stickers/#findComment-6228400
I've had 2 in as many yrs n now I've got a daily because I don't know what happens and don't really wanna find out the hard way umm pretty much everything to low,cooler,wheels etc here is a couple of pics of it
http://m.facebook.co...100001516688882
Not everyone uses facebook you know. Post pics, lol. I found appearance makes a difference too. If your young and wear a white hat that doesnt fit properly on your head, you may be defected. I had an mr2 that sat on 20's with 2 tone paint and was followed briefly by HWP but never even got pulled over. Who really know what goes through their heads?
Edited by NRV155
https://www.sau.com.au/forums/topic/390285-3-red-stickers/#findComment-6230347
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
