I have a room available to rent, in a new house (3 years old) in new estate. Has ducted gas heating and ducted evaporative cooling.
Choice of 2 rooms (both same size), your own bathroom, shared kitchen / lounge. Room is currently unfurnished, but I can supply bed if necessary.
Looking for $170 pw, which includes utilities (electricity / gas / water).
PM me if interested.
https://www.sau.com.au/forums/topic/390389-room-for-rent/
Well im sorry, i wasn't born and raised in australia. Im just here as a student furthering my studies and i didnt know that Tarneit is the name of the suburb as the only places i travel is between the city and clayton. Sorry if i annoyed you, but thanks for the information anyway.
https://www.sau.com.au/forums/topic/390389-room-for-rent/#findComment-6227168
You guys will get along like peas in a pod :thumbsup:
The question was asked immediately after an exchange that addressed the exact same point. I don't think you need to be a rocket scientist to make the connection.
https://www.sau.com.au/forums/topic/390389-room-for-rent/#findComment-6233923
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
