I got hold of a turbosmart boost controller, the bleed vavle style ones, I've put the boost up around 2 - 3 psi and I cant rev past 5000rpm!!!! It pings too much!!!! :ghost:
My mods are:
3" Mandrel bent cat back exhaust
Pod Air Filter
What should I do to recitfy the problem? (Please dont say put the boost back down, coz then it defeats the purpose of modifying it doesnt it! duh!)
Thanks guys!
https://www.sau.com.au/forums/topic/39055-need-help-pinging/
put the boost back down til you get an intercooler.
or, get an air box to lower your intake temps....
but either way, a 2 psi increase (bringing it to around 9/10psi) causing detonation with those mods is pretty bad.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-792763
what Christian said,
turn the boost down until you get a FMIC and a cold air intake system (either ducting from the front bar into a modified airbox or whatever else you come up with).
whats more important to you??? having a car that drives reliably or a sick hectic motor that'll shit itself sooner rather than later?
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793108
Since you've put it so well - Sick hektic :cheers: - Hahahaha joking joking
Yeh I just found out I've done 15,000kms since buying the car in which I dont know when the Sparkies have been changed so they will be changed soon.
Are Iridium plugs really worth the $16 each asking price??
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793124
yeh mate.
but in all honesty a FULL service should have been the first thing you did when buying the car.. unless there's a log book history of it being done in a reasonable time frame
I had nfi when anything on my car was done so we did everything the week I got it
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793136
If your car is pinging like mad with 2psi extra you've got some *big* problems.
Are you sure its not a missfire? Thats much more common at 5000rpm, do a search, there are heaps of suggestions for solutions.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-793256
From experience, prolonged use of octane boost will stuff your plugs, a real pain especially if you have forked out for iridiums.
As with what Prank said, if you are pinging with such a small increase in boost, that is defiantely a cause for concern and I would bet that there is something else going on. My advice is get the car to a reputable workshop asap for a complete checkup before things really go pear shaped.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-794033
Do a *full* service on it. Including Dyno tune / Power run - FIRST UP.
* Plugs
* Fuel Filter
* Oil Filter
* Air filter
* Oil
* Gearbox and Diff oil too
* Drain & Flush your radiator
* Cheack your fuel pressure
* Make sure you have no vaccuum leaks or pipe leaks - ie intercooler piping etc
Do not attempt to increase boost / power without knowing where you are starting from. ie get a baseline.
Do a compression test / leakdown test also. Just to be sure and for a baseline.
Plan your mods - do them bit at a time and get dyno results between mods.
Do not use octane boost to fix continual pinging.
Report back here with your progress and we will keep advising you.
You should be able to run 2-3 PSI on top of stock without any problems - bit get a bigger intercooler to be sure - a GTR cooler for example.
Hope it all goes well
When all else fails a 50 HP shot of NOS should fix your pinging :D
Cheers,
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-794824
* Plugs
* Fuel Filter
* Oil Filter
* Air filter
* Oil
I would suggest having your timing belt changed also, espically if your car is getting towards the 100,000kms mark.
Are you running an aftermarket boost gauge? sounds like a dumb question... but the stock one is not worth much I found.
Cheers.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-795224
I would be careful with that one... I first installed the boost controller (as I just couldn't wait to feel that bigger boost) even though I had the boost guage there ready to go... took it for a spin with what we guessed to be about 0.8 - 0.9 bar, was sitting just off the line with the +7 on the dash. Went like gold, but missed at around 4500-5000 rpm. installed a boost guage and it read 1.45 bar... hence the miss!
Just be careful and even see if you can borrow a guage of someone just to set your boost!
Dan.
https://www.sau.com.au/forums/topic/39055-need-help-pinging/#findComment-796457
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
