hi guys ,
im looking at purchasing the following in 19's for my r33 gtst . just wondering if any one has fitted anything similar in 19 ,iv looked around on sau and google to try find as much info but its limited. im just wondering will 19s be acceptable or is 18s better, im also after an agressive fitment , any recomendations with offset etc as i think they have a few different sets going around on ebay . any info would be appreciated
http://www.ebay.com....=item1e6a5c7fb1
Edited by sky017
https://www.sau.com.au/forums/topic/390805-rota-grid-fitment-on-r33/
go 18s, im running rota grids 17*9 on front +5offset plus 25mm extended LCA so prob be around -10 to -15 and 17*9.5 on rear +12 front and rear guards have been pumped out so depending what guardwork you want will determine what offset you get.
thanks for the reply.
do you think 19s will be too big , i was thinking 18s but i thought i want something bigger as iv never had 19s on any of my cars. do you think i should order 9.5 all around , or go 9.5 and 10 ? i was thinking if i got 9.5 all around , i could always use spacers later if i wanted more or an agressive fit
Yes
Buy wheels that fit correctly the first time
... and don't buy Rotas :thumbsup:
I say go 18s because in my opinion on r33 guards 18s are the biggest id go and anything bigger doesnt suit it but up to your personal preference. Id go staggered 9.5 front and 10 on the rear itll look good.
And what wrong with rotas? just one of those people that hears a story about someone saying there shit and they brake so you just keep spreading it? I know alot of people using the rims and have no problems with them. Not everyone can justify spending 3-4k on jap rims when you can spend that money on something else more important.
boostn0199 - thanks for the postive comment , yes i agree 3- 4k on wheels is unjustifiable in my eyes . so would this be the correct offset to suit front 9.5 +20 , and rear 10 +10
iv been a bit apprehensive about buying them until i know the right fitment , iv never really sourced wheels my self other then going to a tyre place , i think the rotas look good and bang for buck
The fronts will need a rolled at that offset and maybe tiny flare but probably should get away but rears will need a roll and flare. The way I ,measured to get the rims perfect were basically just played around with old rims and spacers and washers to simulate the new rims specs and see how they sit.
If you know what your current wheels on the car are you can use this to give you an idea how much more they will stick out.
http://www.1010tires.com/wheeloffsetcalculator.asp
I went 9.5+30 for rear & 8.5+30 for my fronts on my R34 & they just sit in the guards.
  • 1 year later...
hi guys ,
did you end up getting these? I'm looking at the same wheels now but I'm worried about them clearing the brakes, they would be getting posted from the other side of australia so i don't want to have to pay postage if i have to send them back
Everyone always talks about sizes and offsets but the amount of camber you run is just as important for fitment.
How much negative camber are you running and wheel & tire size? You're a GTST right?
About 1.5 degrees. I like to keep plenty of rubber on the road. I have 19 x 9.5 with higher offset (+35, maybe, unsure) Buddy Club P1's. I'm not much for tight fittment though.
Edited by GotsWapan
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
