http://www.ebay.com.au/itm/800hp-Street-Legal-R33-Nissan-Skyline-Turbo-Drag-Drift-Race-/280823080195?pt=AU_Cars&hash=item41625c2503
Anyone know if this is legit? might buy it for the the running gear.... cheap drift car for the missus.
https://www.sau.com.au/forums/topic/391202-998-139mph/
Come on Trent surely you would know a coated GT35R isn't worth $9,000 like that ad says :laugh:
Then... 560rwkw with a GT35 on E85... lol... John Elliot.
New ebay user as well...
Maybe give Hills a call? Perhaps they know of the car if they did actually build the motor?
https://www.sau.com.au/forums/topic/391202-998-139mph/#findComment-6227482
HAHA boom didnt even see that... gonna blame my moving shop til 3am on that one....
delete thread for my blatant stupidity....
https://www.sau.com.au/forums/topic/391202-998-139mph/#findComment-6227534
Tell you will pay cash asap when he sends them.
Haha this is what I said:
Hi mate,
Could you please upload pictures of the 9.98 time slip, dyno graphs and receipts for engine work? I'm quite interested in your car as I've been looking for a project to come along for some time now; have got money ready to go and willing to pay far more than the current bid stands. I can see the money and effort that has gone into your car, but one can never be too safe, I've been stung before. Looking forward to your reply.
Thanks.
https://www.sau.com.au/forums/topic/391202-998-139mph/#findComment-6228273
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
