Guys,
I have now finished off the R34 GTT with the East Bear Masterpiece Collection GTT to GTR bodykit.
All other work is completed except for the FMIC.
I want to use the return flow type, to retain the "over the engine" style intake.
http://www.kudosmoto...-neo-p-944.html
I am going to use the intercooler linked above.
I'd like to get some feedback from the members who have installed this unit in the past.
Has it bettered your response or not?
My car is running factory intake and airbox with an HKS panel filter.
The turbo has been hi flowed and is running a modest 10 psi, making 335HP at the fly wheel.
My aim is to better the response, and cool the air better, not more power.
Has anyone found that installing one of these units, actually increases lag?
Many thanks.
Jim
Edited by TR33GT-001
https://www.sau.com.au/forums/topic/391651-blitz-return-flow-fmic/
Guys,
Many thanks.
Jim
Hey mate, cant say i noticed a difference with lag or response, it pretty much didnt change, although i'd def recommend one if you do chose to increase your power down the track, especially with a hiflow turbo.
Cooling the air better is how they make more power.
What are you comparing it with? Do you have a fmic now or the standard GTT smic?
I had a Trust smic (bit bigger than the GTT one) on my Stagea making about 220awkw and changed to a Just Jap return flow making 240awkw with a GCG highflowed GTST turbo on about one bar. I didn't notice any increase in lag but then there was a power increase as well.
I have now changed to an HDi Hybrid fmic with a Greddy copy FF plenum on an RB30 so can't notice any increase in lag or response.
If you have the GTT smic now there will be no improvement in lag but it should be easier to make power.
If you have a fmic now I doubt that you will notice any improvements.
It's presently the OEM SMIC.
I'll wait for a few more replies before deciding.
Thanks for your comments so far guys.
(I'm being overly cautious, for good reason. Money!)
Jim
That's a pretty good power figure for the stock smic. :)
I've always said they were underrated. People used to go on about heatsoak but that was only ever a problem for me on the dyno - not on the street or track.
Having said that I think the Blitz return flow is a good unit and you could wind your highflow up a few psi and you will notice a good power gain with no noticeable downside.
You could save a few bucks by getting this one instead (the one I had) http://justjap.com/store/product.php?productid=17355&cat=0&page=1
But if money is really tight you could carry on as you are until you are ready to upgrade.
You will see a slight pressure drop it's way bigger the stock cooler your also adding piping but would be hardly noticeable but thats my 2c it is a deffinent improvement over stock the gains will out weigh the cons
I have the Blitz LM on mine. Didnt notice any decrease in throttle response or any increase in lag with the stock turbo.
Putting 300rwkw through it now with no dramas. Keeps the intake temps very low. And removes temps very quick if it heats up in traffic etc. It will drop 20+ degrees in a matter of seconds. Even just giving the throttle a stab and holding the revs a bit higher at a standstill the temps plummet.
On the track on a warm day the temps range from 25-35'C giving it full beans. On the road it, 18-25'C.
im using a big ARC return flow dont know to much about them but have heard after a car was tuned by trent after 15 runs the intake temps didnt change at all
and have seen a few results make over 300rwkw with no problems
havent looked into the other brands much so cant really comment on them and i cant say if i noticed a difference as my car came from japan with it fitted
but when my car was stock with full 3 inch stainless dump pipe and exhaust,metal intake pipe 9psi i raced my friends r33 with excatly the same mods except the intercooler he was using a just jap one
head to head i was 2, 2.5 car lengths in front
not sure if that was the coolers doin or not
hope this helps
Lol companies always give redicolous power increases that will never happen. A cooler isnt a power increasing mod like rurbo its a mod like fuel pump it removes a restriction and allows you to get more power out of the pther mods like a turbo.
At what power level though? up to around 300kw they will both be the same its only once the jjr starts to reach its limits and be a restriction is when that could happen. For instance if its just a relatively standard car and you put one on you wont expect a power increase of 80hp,
main difference ive seen with the arc coolers compared to the rest is after 15-20 dyno runs the intake temps havent moved and the arc cooler is cold on both sides i know as i have one and tested it
but dont get me wrong im sure all the other return flows will be good just saying if this guy can find one i wouldnt think twice snapping it up i was lucky my car came from japan with it fitted i wouldnt like to pay 2-3k for a return flow cooler hahah
Yeah I agree the ARC and other jap brand coolers are better than the china ones and will keep temps down better if I have to buy one again it will be a jap brand, I was more trying to point out the fact that some people think a intercooler is a instant power mod.
Yep, an intercooler is a supporting mod only, for the intended power level that is targetted. All good guys. I am going with the Blitz unit, as part of the final mods. Thank you all.:thumbsup:
killer cooler the blitz return type.
  • 3 months later...
Good to hear the blitz turnflows are good for up to 300kw? but how would it compare to the cooling pro option from justjap?
I was set on getting a black cooling pro but im just worried that its not going to be up to the job.
I should also mention I'm planing on getting a HG turbo later in the year and i want to make the right choice now so there are no hassles(i.e. struggling to make the most out of it) later on when tuning the thing.
Thoughts on either cooler for 250 ~ 300 kw applications? - as you can see i havn't yet chosen my ideal setup.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
