Ok guys, it's on again! the official SAU-Vic Mt Buller cruise 2012
this is a members only cruise, and as such only paid members will be able to view this link
My http://www.skylinesaustralia.com/forums/topic/391829-mt-buller-2012-its-on/
( all the more reason to join!;) )
https://www.sau.com.au/forums/topic/391830-mt-buller-2012-its-on/
why's that? :)
you scared of a bbq? ;)
Depends what you're bbq'ing, but more than likely not...Sandra on the other hand is partial to chicken and doesn't eat much else lol, especially you're fancy stuff I'd imagine...
If you are sans gf, you are welcome to passenger with me. Gangsta beats all the way up there :thumbsup:
No homo
Strong homo, but if I go it'll be with the gf....Thanks for the offer though (homo)
Me and...the missus...are most likely in for this.
Not to detract anything from Hamish's cooking, but the stuff he's done at the lodge hasn't been over the top fancy, just really well cooked tasty food. I ate a good deal of his cuisine last time and I won't touch anything that didn't have parents.
But yeah can always byo foods, I'm sure we won't have an issue cooking it.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
